Refrigerators Logo
Question about AEG Refrigerators
Please advise where I may obtain a service manual for a AEG SANTO 78763 KG Fridge Freezer
Posted by Peter Fishwick on
My AEG Santo freezer is leakin water on the floor every few days. There is also a build up of ice inside the bottom of the freezer, even though we very recently defrosted the freezer. This fridge/freezer...
try pulling out the fridge very slowly, any signs of hard resistance than stop. there should be a main water shut off back there. if still uncomfortable with this you can always shut the main water off to the house before trying. hope this helps.
1helpful
AEG SANTO No_frost refrigerator beeps with 5 sec freqency
We have the same fridge, and I could not find my model either!
The label is hidden on the bottom of the top part on the left side, you need to take the veggie tray out to see it. I spent about 3 hours finding the model on the net, and in the manual it said where to look lol.
This mysterious model is the AEG SANTOS 3895-6 KG AKA S3895-6 KG productnumber 928405123-- last two digits can be 00-33.
We had the same problem, solution: press and hold the ON button for minimum of 3 seconds. The fridge switches off. Wait 10 seconds and repress the same button. That´s the quick fix.
To make it go away completely switch off fridge, pull out plug, and thoroughly clean the air vents on the back below using compressed air. After this the problem went away permanently.
Good practice to airclean every 6 or 7 months. You can find the manual for the S3895-6 KG on http://www.electrolux-ui.com:8080
1helpful
AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Can I buy spare shelves for an AEG santo 3790-6 KG fridge/freezer
MAYBE,GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND SEE IF THEY HAVE YOUR PART,ALSO TRY REPAIR CLINIC.COM-MIKE
5helpful
2answers
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
AEG Santo
here is a link where you can download an english version http://www.nodevice.com/user_manual/aeg/refrigeration_1192865302/santo_3442_kg_glassline_621672048.html
you will need adobe reader to be able to read it, you can also download it for free. if this helped you then please leave feed back,cheers.
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
4helpful
AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Top AEG Refrigerators Experts
David Shaub
Steve F
Tom Chichester
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
