SOURCE: Icing up in bottom of the freezer
I don't know the particulars of your brand, but if it is frosting up Most fridges will have a bad heater element, a bad defrost timer (or controller if it is electronic) or most likely a bad defrost limit switch. This is a switch mounted on the inlet line of the evaporator with a clip and senses when the evaporater is defrosted so that it does not get too hot and start melting parts. This switch should have zero ohms of resistance when cold (below 40ish) and be completely open when above 40 or so. The easiest way to test it is take the wall covering the evaporater off and locate the plugs for the swiths. Test continuity through it. If it is sitting in ice, it should have no resistance. If it is open and in ice (infinite resistance) then it's bad.
SOURCE: freezer compartment
You need to defrost the whole fridge and at the back in the freezer compartment you will c a small drainage hole.. look for it.. The get a piece of say hanger wire and clean this pour some hot water from a kettle down it and then start your fridge up again. that should sort your problem out ... if not then its either a sensor or a board fault...
machine has a defrost issue, defrost mi metal or defrost timer
SOURCE: Bosch intelligent frost free 44
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
SOURCE: sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
