20 Most Recent AEG S72348KA ST STEEL Refrigerator Questions & Answers
FRIDGE HAS STOPPED WORKING
Top of Form If there is no coolingat all , before we go further we must confirm the first step of confirming thecompressor and gas pressure. So shut off the fridge and leave it off while youclean and check the evaporator for frost. If frost is seen it is a goodindication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happenin about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer andfridge. If there is no ice formation we have a big issue as the compressor andgas must be checked out. If compressor is running check the pressure, get helpto test gas pressure. If not you will need to fill up ,If gas pressure is goodthe possibility of the compressor being inefficient is high. In such a case youmust take consensus to estimate and decide, if RPM of motor is low checkcapacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling tocontinue and the fridge to cut off . If not the auto defrost timer, or thethermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shutsif the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come tothe solution.
6/28/2011 10:44:35 AM • AEG S72348KA ST... • Answered on Jun 28, 2011
0answers
FRIDGE TO COLD DOES NOT DEFROST AUTOMATICLY WHAT
normal operating temp of a fridge is between +2C to +5C(any colder and lettuce freezes)
10/3/2010 4:17:15 PM • AEG S72348KA ST... • Answered on Oct 03, 2010
From time to time stops
A refrigerator must defrost 2 - 3 times a day. It does this via the automatic defrost cycle. When the cycle starts alll motors shut off and there is a heating element that is in the evaporator / freezer section of your unit. That heating element melts the ice until the 60 Deg F bi-metal thermostat cycles and terminated the automatic defrost cycle. During the defrost cycle is is normal to hear a hissing sound as the melting ice drips on the heating element assy. Addiionally you may hear coolant gurgles as the unit shuts off to start the defrost cycle and the coolant system equalizes the internal pressures between the pressure and return lines. Again another normal sound. If your unit did not stop to defrost 2 - 3 times a day in a matter of 3 to 4 days you would have a large block of ice in the back of your freezer section and the evaporator fan blades would be hitting that ice block. The freezer would say cool yet probably no longer make ice. Also the fresh food compartment would start warming up. Hopefully this resolves your concerns. If you need more assistance just respond to this post and I will help you.
Thanks for choosing FixYa.
Kelly
9/5/2010 8:46:05 AM • AEG S72348KA ST... • Answered on Sep 05, 2010
Thick ice is building up on the inside back wall, i'm
not defrosting it totally, unplug unit and use a blowdryer to defrost the return air ducts, they are located behind the panel on the rear wall of the freezer
11/7/2009 8:11:30 PM • AEG S72348KA ST... • Answered on Nov 07, 2009
3answers
Tripped earth leakage, i made
Itjust sounds like a stuck or broken switch& look on inside of door to see if stuck before you change it ..and no this is not going to affect the unit at all
12/12/2008 12:25:48 PM • AEG S72348KA ST... • Answered on Dec 12, 2008
3answers
Hello. Please could you tell me where the thermostat is on an AEG Santo fridge freezer model n71 840?
May not be the thermostat. Could be the fan motor.
5/19/2022 4:16:35 AM • AEG... • Answered on May 19, 2022
Temperature of my AEG Arctis freezer started rising for no reason.
sorry but only a local repair service can help you
9/19/2021 11:57:35 AM • AEG... • Answered on Sep 19, 2021
Arctis 3100. Why isn't it freezing?
There must be a gas leakage due to which the refrigerator is not cooling. Better call a technician to fix it.
2/17/2021 6:28:27 PM • AEG... • Answered on Feb 17, 2021
2answers
My AEG freezer works fine but the fridge doesn't seem to cool
Possibly evaporator fan not working or defrost problem.
5/29/2020 4:04:38 AM • AEG... • Answered on May 29, 2020
My aeg inbuilt frost free fridge freezer is collecting ice under the bottom freezer compartment. how can I stop this happening
Sounds like the drain pan or tube is frozen and clogged You need to shut off the unit and empty the freezer section and check the bottom of the rear wall of the freezer for the drain pan. use sink hot water to defrost and a turkey Baster to clean the hole and the hose.
6/20/2019 12:01:26 PM • AEG... • Answered on Jun 20, 2019
Freezer does not freezer does not work on an age fridge freezer
no gas or faulty compressor not worth repairing
2/2/2019 9:54:49 PM • AEG... • Answered on Feb 02, 2019
I have an AEG SANTO OKO fridge unit only about 1 year old. We just cannot open the door without it being pulled 2 inches on every open. I have since placed it on a rubber mat with no success
You have very good door-seals, with strong magnets on the refrigerator. I suspect, You must pull hard to open the door. Does the fridge have 2 wheels? It may only stand firm on 2 "legs" and not 4. This problem is the first, I ever heard, I do not know this model, If it is a Refrigerator that is not very heavy, this can happen. When the door seals are very good, what can happen is The door has been closed and the air inside the fridge becomes cooler and cooler. The air inside the food-compartment contracts, because it cools down and pulls even more on the inside of the door surface, actually pulling the door shut. ( a negative air-pressure inside the fridge) compared to the outside of the refrigerator. A trick I am using is, 1.) I place my finger between the door and the cabinet-frame. 2.) Then, with the finger, index or middle finger, I push gently against the Door-Seal (Gasket). for 1 or 2 seconds, This allows the Air from outside, (higher pressure) to flow into the food compartment of the fridge and now it is easy to open the door. Let me know if this works for you. Appreciate to be alive and be kind to others. Klaus (Electrical & Refrigeration Technician) Toowoomba, AUS
2/6/2018 11:14:37 PM • AEG... • Answered on Feb 06, 2018
AEG S72348KA ST STEEL Refrigerator Logo
15 questions posted
Top AEG Refrigerators Experts
David Shaub
Steve F
Tom Chichester
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
AEG Refrigerators
  • AEG Refrigerators
Most Popular Question
from time time stops
  • Refrigerators
