20 Most Recent
HEWLETT-PACKARD LaserJet P3005x Printer Questions & Answers
49.4c02 error
49.4c.02 error is a firmware error.
Very rarely is a "49" error cause by hardware.
First remove the network or printer cable and reboot. If the printer comes ready the problem is with a print job waiting to be printed. Most likely a PDF file that the printer doesn't understand how to print.
On a windows machine Start, Devices and printers, locate your printer and double click then click on "What's printing" and delete any files waiting to be printer. ( You'll probably see one on the list with the word "error" on the line
Hp laserjet 5100n
Go to the hp.com site and search for said driver. Sometimes they do not update their drivers for older machines, but I am not familiar with this one. Good luck. Once a year Staples will have a special where one can trade in an old machine for a discount on a new HP.
HP Laser printer USB connector broken
What model? Connector on the outside or on the mainboard? If on the mainboard, replace it. If on the front, you should be able to just replace the connector cable and/or mounting.
Cannot receive fax
make sure you have a phone line plugged in correctly (into the in plug) and set the printer / fax to recieve auto. Do not pick up the phone while recieving the fax, If thei does not work, check your setting in the software.
Hp f4435
I'm assuming you have the correct drivers loaded and correctly configured.
Set power switch to off.
Unplug it for 1 minute.
Plug it back in.
Turn it on.
If it still won't work, I suggest replacing the power supply.
If it still won't work, I suggest you replace it.
Laserjet p1320
Hi
This printer should have problems with the fuser unit or the power supply
