Question about HEWLETT-PACKARD Office Equipment & Supplies
Needm location of reset buuton on HP C6180 All-in-One printer
Was told i needed to reset my printer but do not know location of the reset button. Had a bad paper jam, cleared it but due to printer saying "ink set-up failure-reset"
Posted by amber burke on
syed jabir ali
    New Friend:
  • 110 Answers
Please click An Ink System Error Code Displays on the Front Panel to access the steps that should resolve the issue.
If issue still exists, then the printer need to be serviced.
Posted on Nov 30, 2014
1 Related Answer
davidmamian
Davit Mamyan
  • 552 Answers
SOURCE: Put a new toner in, now says "paper jam"
There is little of paper in printer. Take the toner out and with very attention see, it must be in taht place, from where the paper going out, or that place from where taking paper, it can bee small paper.
Posted on Oct 28, 2012
How do I reset displaylanguage to english HP C6180
You can do a reset on your printer.Unplug the power cord of the printer.Press and hold the # and 6 buttons together and then plug the power cord back into the outlet.Keep holding the 2 buttons until the display goes blank or RESET is displayed.If the printer automatically turns off, turn on the printer.The printer should start up and you will be able to select language code.
Oct 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
How do i reboot my hp c6180 printer
This seems to works for me and doesn't appear on the HP support site nor in the manual...
1. Power down the printer (use on/off button) and remove power cable. Wait 2 minutes.
2. Hold down Help and OK buttons together while plugging in the power cable.
3. I held the buttons for around 5 seconds and when I released them, the printer seemed to go back to a hard reset - all sorted!
Hope this helps!
R
Jan 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printer never completes the startup sequence, it
just reset the printer
unplug the power cable without turning off the printer
press and hold # & 9 Button
while holding down pluggin the Power cable and it will reset the printer (everything)
**** U will lose everything that has been saved in the printer settings
Oct 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 boot - init loop / power on-off loop
The Formatter board (main logic board) is faulty. You need to take the printer in for repairs to HP, in my experience though it usually works out better to replace the printer.
Aug 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Impropershutdown
Press 6 and # while disconnecting the power cord (wait a little bit) and connecting it again. When the display is turned on again you can release the buttons.
After this reset you need to enter language, location and any wireless settings etc.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
My photosmart hp C6180 keeps saying printer alignment failed and it will not print anything with black ink. I have replaced the black cartridge 3 times. What do I do? It will print all the other colors...
C6180 reset:
Perform a semi-full reset to set all user menu settings, telephony parameter settings, country/region and language UI, fax memory settings, fax journal information, speed dial and broadcast lists, personal header information, and junk fax settings to the default settings. Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457329&cc=us&lc=en&dlc=en&product=1153494
Or a Full reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720248&cc=us&lc=en&dlc=en&product=1153494
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 12, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 all-in-one error message 83c00020
Try unplugging the printer from power for about 10 minutes and then reconnect it and see if that will reset it. You mentioned the error code 83c00020 is that on the printer screen or somewhere else?
I wasn't able to find that exact error is that the way the error actually displayed?
Reply back and let me know. Hope this helps. Please remember to rate this information.
Thanks
Nov 10, 2008 | HP Photosmart C6180 All-In-One InkJet...
Need to change region settings
it would be best to call HP TOTAL CARE. they would know how to reset it.
Aug 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer
Resetting the All-in-One
  • Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Aug 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
Open Questions:
125 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
George Mclaughlin
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
