20 Most Recent HEWLETT-PACKARD LASERJET PRO P1606DN PRINTER Questions & Answers
In the settings menu there should be a economy mode. Change to that mode.
HEWLETT-PACKARD... | Answered on Sep 22, 2017
Happened on our print server this morning for the first time. We have 4 of 1606dn in our organization. Reset the print spooler and that brought it out of offline mode
HEWLETT-PACKARD... | Answered on Aug 10, 2017
It needs a new cartridge
HEWLETT-PACKARD... | Answered on Apr 06, 2016
Bad formatter most likely But to be sure delete all jobs
from the que.
HEWLETT-PACKARD... | Answered on Feb 10, 2015
did you replace orginal HP cartridge? if you are change refill or any other kind of manufature cartridge , there is chip is not working properly, that's why ligh is blinking, use orginal HP toner or good quality brand
HEWLETT-PACKARD... | Answered on Oct 29, 2014
Un install the drivers.
Connect through usb cable observe system recognised the printer?.. if recognised, reload the drivers & chk for the prints.. if not issue with formatter..
Insert net work patch cable., print configuration page., verify the ip address., load the drivers as network printer., chk for the prints., if not printing., ping ip from system... chk withnamother cable.., fotmatter issue..
HEWLETT-PACKARD... | Answered on Sep 23, 2014
bad toner; bad fuser; something on transfer roller.
HEWLETT-PACKARD... | Answered on Aug 03, 2014
first check printer IP & then ping it & assign to printer then it will work, if not swipe the formatter board then check.
HEWLETT-PACKARD... | Answered on Jun 13, 2014
In internet explore bar type the IP of the printer ,u will EWS go the printing source, make it none.
Through drivers you wont get the mirror image, but if you install thir party software such as pagemaker etc... your will get it..
HEWLETT-PACKARD... | Answered on May 03, 2014
Please download and run the HP Print and Scan Doctor from www.hp.com/go/tool
HEWLETT-PACKARD... | Answered on Apr 24, 2014
Verify that the network station cable (the one connected to the P1606DN printer) is good and that the connection to the network is good. You can do using a number of methods. But, if you have a portable computer, the simplest method is to disconnect the cable from the P1606DN, connect it to your computer (make sure the wireless on your computer is turned off), and verify that you can connect to your network. If not, you have a cable/network problem.
Otherwise, try resetting your P1606DN printer to its factory defaults:
1. Turn off the printer
2. Turn the printer back on, and while it is initializing press and hold both control-panel buttons at the same time until all the lights blink in unison.
Then put your static IP address back on the printer and hopefully you can now connect. If not, can you ping it from a workstation? If not, the network adapter circuitry in the printer may have failed.
HEWLETT-PACKARD... | Answered on Mar 25, 2014
the cartridge in this machine has a chip on it but it should still print if you get a toner low message. the chip counts pages not amount used to print so if you are doing light print jobs it does not no it only counts the cycles
HEWLETT-PACKARD... | Answered on Jan 04, 2014
is it red... if no colour the wifi card has either come loose or not working any more.
HEWLETT-PACKARD... | Answered on Nov 03, 2013
Try HP print and scan doctor
HEWLETT-PACKARD... | Answered on Oct 22, 2013
Electrical spike may have toasted the circuit board. Common occurrence when power returns after outage
HEWLETT-PACKARD LASERJET PRO P1606DN PRINTER Logo
36 questions posted
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
George Mclaughlin
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
LaserJet HEWLETT-PACKARD
  • LaserJet HEWLETT-PACKARD
Most Popular Question
hp laserjet p1606dn network adapter no
  • Office Equipment & Supplies
