The conditionre is washed out by adding water which fills the level in the dispenser up until it activates a syphon effect. I found with mine that years of dampness had led to all sorts of muck blocking flow of fresh water. Take off the machines's lid, then extract, take apart and clean the plastic unit that is above the conditioner dispenser.
SOURCE: washing machine problem
at the back of the conditioner compartment there is a syphon. check the tube of the syphon is clear. put on rinse and at the point the conditioner should be taken, open the drawer and check that there is a jet of water into the conditioner area. if not, there are some holes in the roof of the top of the box. these may be blocked. clear with a hairpin or similiar
SOURCE: Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
SOURCE: fabric conditioner drawer does not empty
The inlet to the conditioner compartment is probably blocked.
Get a thin piece of flexible wire and make a right angled bend on the end about 1" long, and poke it into all the holes u can see in the top of the dispenser compartment, particularly the ones at the front right side.
This should solve the prob.
Plz rate this solution .
Thanks
SOURCE: Conditioner drawer not emptying
Do you use a thicker type of softener? When I had this problem with my washer I added water to the softener to thin it out, as it just seems like it leaves a build up that clogs repeatedly otherwise. hope that helps
SOURCE: fabric conditioner drawer not emptying
take drawer out to clean. take it apart and clean top bottom back and front, sounds like theres a blockage stopping the conditioner from syphoning out'
