FixYa.com
Bosch Axxis+ WFR 2460 Front Load Washer
All Products > Bosch > Washing Machines
Problems with Bosch Axxis+ WFR 2460 Front Load Washer?
Troubleshooting and Support
Solved Problems for Bosch Axxis+ WFR 2460 Front Load Washer RSS Feed Post a New Problem
Pump Blocked - Cannot open/remove cap
The Washer says that the pump is blocked. The manual says that I can open the pump cap and clear out whatever is...
2 Solutions
Bosch WFR 2460 washing machine
My Front Loader Bosch Axxis+ says pump is blocked. I take off the cap in the front and lots of water comes out, but...
1 Solution
change from 3 wire to 4 wire dryer cord on...
terminal block has two terminals labeled "L" and one labeled "N" and the previous three cord had the...
1 Solution
display field
I have a two year old (?) bosch axxis wfr 2450 and the display field has burned out. i cannot read ANYTHING in the...
1 Solution
Front door will not open
My front door will not open. I have a service call, but they can't come for 3 weeks. Need some suggestions of how to...
1 Solution
Started with a clunk, now won't come out...
We moved our washer to new house. No shipping bolts were found, were very careful during transport. Worked fine for 2...
1 Solution
Bosch WFR2460 Leaks
The washer leaks somewhere out the bottom of the machine durring the spin cycle. I have drained the hose and cleaned out...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Bosch Axxis+ WFR 2460 Front Load Washer RSS Feed Post a New Problem
Main Pressure Switch Test or Calibration...
My pump started making noise, then eventually I started getting the "Pump blocked?" message. I drained the...
Post a Solution
My Bosch washing machine not working...
Hi I bought a Bosch excell Max front loading washing machine from the uk and now I am in Australia it is only 1/2...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Washer TypeWasher
Load TypeFront Load
Weight Capacity13 lb.
Wash
Wash PresetsPermanent Press, Delicates, Hand Wash, Wrinkle-Free, Soaking, Cotton
Spin Speedsmax. 1200 rpm
Temperature Levels6 Levels
Washing MethodDrum
Extra SettingsQuick Wash · Heavy Duty
Convenience
Additional FeaturesChild Safe
Control FeaturesDigital Display · End-of-Cycle Signal · Time Remaining Indicator · Dial Controls · Delayed Start Timer
DispensersFabric Softener Dispencer · Detergent Dispenser
Efficiency
Annual Energy Consumption194 kWHrs
Water Consumption per Wash13.2 Gal.
Other Features
Exterior ColorWhite
Dimensions
Overall Depth22.25 in.
Overall Height33.5 in.
Overall Width (Display)23.63 in.
Warranty
Warranty1 Year Parts · 1 Year Labor · 5 Year Parts
Bosch Contact Information
Main support number01895 878093
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
