SOURCE: dyson dc17 animal
on the bottom plate are 3 spots, one in the center and one at each corner, that need a flat head screw driver to loosen. turn left to unlock, this will remove the plate so you can clear the debris from the brush.
SOURCE: Trying to replace roller brush on DC07 model
Hi the dyson is a bit strange with this the dyson engineers use a hook to put under the belt and pull it out to allow the brush to be removed I used a metal coat hanger to make the hook after seeing the dyson engineer when ours was under warranty if you make the hook with the wire doubled up it works fine for me hope this is of help Fred
SOURCE: How do you remove the roller brush from a dyson
you will need a special bet tool. you can buy one from ebey. search for "dyson special bet tool" it is about $15. don't use your hands as the belt is very tight and you will hurt your fingers.
SOURCE: My Dyson DC17 Animal brush roller makes noise when
need replaced belt and Brushbar Assy
Brushbar Assy part no:911961-01
Belt part no: 911710-01
Hi its Darran at Dyson.
You may find it useful to remove the soleplate from the base of the machine and make sure that the brush bar is fitted correctly.
Once this is done, make sure there are no hairs or threads wrapped around the brush barm, particularly
at the ends.
With the soleplate removed you can also ensure that the brush bar and housing are free of blockages.
Once checked, re-fit the soleplate and test the machine.
I hope that this information is useful to you. If you need any further help or advice, contact one of our Ask Dyson experts on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
