Have cleaned ink absorber pad and reinserted but printer shows 5BOO error code on Canonpixma 5350
The 5B00 error code on a Canon Pixma printer indicates that there is a problem with the ink absorber. It could be that the ink absorber is full or there is a problem with the ink absorber assembly. Here are some steps you can try to fix the issue:
1. Turn off the printer and unplug it from the power source.
2. Open the cover and remove the ink cartridges.
3. Check for any foreign objects or debris inside the printer.
4. Check the ink absorber pad and make sure it is properly seated.
5. Reinsert the ink cartridges and close the cover.
6. Plug the printer back in and turn it on.
If the error persists, you may need to reset the printer. To reset the printer, follow these steps:
1. Press and hold the Stop button for 5 seconds.
2. While still holding the Stop button, press and release the On button.
3. Release the Stop button.
If the error persists after resetting the printer, you may need to have the printer serviced by a professional.
