20 Most Recent
Canon Pixma iP2700 InkJet Photo Printer Questions & Answers
How do you repair error
It show your printer's ink absorver is almost full. So try to solve by using the following methods.
Here's How to solve Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready for use thanks.
Canon iP2770 paper jam but
press and hold the circle with inverted triangle buttons for at least 5 seconds.
printer will self-restart
after this error blinking is gone.
Service error 5100 on Canon
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
- Turn off printer
- Remove both the cartridges from the printer
- Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
- Return the cartridges
- Turn on the printer.
Error will be removed
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Problem with canon ip 2700 .....the printer show
Canon IP2700 6000 Error
Error 6000 tells you that the paper feed roller is not turning, check for any foreign objects in the paper path, a flashlight and small mirror is the best way to look.
yes.. i agree on this statement..
just try this one., its tested by my own experience., first turn off the power of IP2700 printer
then just try to turn the gear of paper feed roller in order to release
the foreign objects..
if error persist, just try to turn the gear again until it works ok.
pls send feedback if its work., salamat., mabuhay pinoy.
How to solve error b200
The print head has a voltage fault. This is usually caused by the logic board going faulty and sending too much voltage to the print head. You will need a new print head and main logic board. This would probably cost more than the machine is worth. Buy a new printer.
How could error code 6000 in ip2772 can be fix?
there is a problem in the gear during initialization of the printer, maybe there's a tiny piece of paper that cause the gear wont move, the best solution is to open the printer to see if there is a foreign object inside in it.. that's all
Canon pixma IP 2770 error code 006
U have to download resetter file http://imadeitthisway.blogspot.com/2010/09/canon-ip-2770-reseter.htmlhttp://m4sjoysaja.blogspot.com/2010/08/how-to-reset-clear-counter-canon-ip.htmlI hope its working
I have a Canon iP2700
Hi. I am almost sure that there is obstruction. Try this. Unplug the printer, turn it upside-down and shake it up and down . Maybe the foreign object comes out . If doesn't. Get technical support
How to install ip2770
Install online is unusual way to do. People usually will download the driver first via internet (online). After installer driver software have been downloaded, we can run the file for installation.
If the installation success,we can connect printer to PC via cable data and we can start to use your printer.
You can download the driver from here :
Download Driver Canon Pixma iP2770or from here :
Canon PIXMA iP2770/ iP2772 Windows AllHope this help, and if you feel helped RATE please !
