RCA R52WH73 Projection Television Logo
Posted on May 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red picture The picture on our TV suddenly is red and there is a "halo" affect around everything in the picture. The set is an RCA Home Theatre and is a big screen, maybe 52" or 54". It is about 13 years old. Thanks for any advice.
Anonymous
Level 3:
President:
  • RCA Master 1,779 Answers
  • Posted on May 03, 2009
Anonymous
RCA Master
Level 3:
President:
Answers
1779
Questions
Helped
579067
Points
5452
That could be just cold solder joints on your convergence circuit board. I would call a svc co. to have them evaluate it. It's not a major repair.
I have a pioneer xv-dv282ap home theatre and there is no audio coming out from the speakers. The only way to make it work is to use an HDMI cable using the speakers from the TV.
use rca red and white to connect to input on home theater,plug other end into tv output,now go into tv settings and find speakers and turn on external speakers,connect hdmi from home theater to tv input,you cannot record tv stations.
Lg plasma 50 trying to configure hdmi to play tv sound through panasonic home theater.
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
Blurry picture with green and red halos around
Ur convergence is dead.Must replaced 2 Convergence ICS,and some or all the resistors.Know how to solders?Buy a convergence kit Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Philips dvd home theather,i didn't get a users manual,i can't get the sound to come out with the tv,it will owrk with the radio. lloyd
I will guide you through it.
Just to clarify, When you say sound out with the tv, which are you referring to:
1. DVD built into to the theatre
2. Pay TV
3. Analogue TV ( or digital TV with inbuilt set top box)
4.Digital TV with a separate set top box
Please indicate which one.
TV: ther should be several set of three RCA Sockets on the back of the tv. Look for the red, whit and yellow Phono sockets. do you have these colours and are any of them labelled TV Out or output?
Philips System: Look for an analogue in, Aux IN, or any other unused RCA (Phono) Sockets ( They MUST be red or white!)
Take a set of red and white RCA leads plug them into the OUT set on the TV, and The "INput" set on the Home theatre, select that input on the theatre and your off and racing!
Please clarify first though!
RCA TV MODEL R52WM24
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
I have an RCA 50 inch projection tv that all of a sudden looks like the picture is warped on the screen.I can not make screen adjustments with the remote to solve it.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Poor Picture on HD 52'' Projection RCA TV nearly 4 yrs old
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Picture Greatly distorted all of a sudden by many yellow lines
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
