On our Polaroid Flat Screen the volume and other input, menu control, etc do not work on either the...
(More)
On our Polaroid Flat Screen the volume and other input, menu control, etc do not work on either the tv or the remotes. All we can do is turn the cable channel through the cable box.
used to get digital channels from my cable company. i bought another tv and it gets all the hd...
(More)
USED TO GET DIGITAL CHANNELS FROM MY CABLE COMPANY. I BOUGHT ANOTHER TV AND IT GETS ALL THE HD DIGITAL CHANNELS THAT I USED TO GET ON MY PANASONIC. IS THERE AN UPGRADE?
When you press the power button, the screen remains blank and after a few seconds the power light...
(More)
When you press the power button, the screen remains blank and after a few seconds the power light begins to blink. i do not hear the tuner power up even though you hear the two clicks of the power supply when you press the power button.
I have a Panasonic th-42px60u and ever since the digital tv switch, I have been unable to get a...
(More)
I have a Panasonic th-42px60u and ever since the digital tv switch, I have been unable to get a certain local channel. I have an antennae, so no cable, and it works great on all the other channels , but won't even receive a signal for the cbs affiliate in San Antonio. I did a channel scan, input the channel (5, 5-1), and still nothing works. My other, older tv gets every channel with no problem and I even switched antennas, but to no avail. What can i do to make this channel work?
television blinking black every few seconds - not sure why? all the cords seemt to be connected....
(More)
television blinking black every few seconds - not sure why? all the cords seemt to be connected. Even when I turn off the cable, the screen continues to blink every few seconds black - it is the television, not the cable. Any ideas?
(More)
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12 digital changeover) can cause the sound to be missing on those...
written by jmorganti
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
