FixYa.com
RCA R52WM24 52 in. HDTV Television
All Products > RCA > Projection Televisions
Problems with RCA R52WM24 52 in. HDTV Television?
Troubleshooting and Support
Solved Problems for RCA R52WM24 52 in. HDTV Television RSS Feed Post a New Problem
RCA Model Number R52WM24
Our tv went from being normal to crazy in the matter of a couple of minutes. It appears as if the picture is bowed. And...
2 Solutions
tv model r52wm24
fuse link f231 keeps blowing how do i find and fix problem
1 Solution
R52WM24
HELLO, I NEED KNOW WHERE CAN I GET A CONVERGENT POWER SUPPLY FOR THE MODEL R52WM24 YX51
1 Solution
Red, green and blue color resolution
the red, green and blue colors are in lines or in shadows on the screen including the menu items.
1 Solution
distorted picture on RCA LCD TV
the picture is curved and distorted with the pictures appearing double The screen is distorted and curved. Also the...
1 Solution
Blurry screen replacing f231 fuse link
The two red wires on the transformer are permitting me to remove the board, It would be easy to replace fuse if I had...
1 Solution
picture convergence and double lettering
I purchased my tv at circuit city as well, with extended warranty which expired 3 weeks ago, now my tv has the same...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for RCA R52WM24 52 in. HDTV Television RSS Feed Post a New Problem
convergence problem
te colors on my tv(rca r52eh74?) are all out of alnement and from looking at some of your problems helped with on your...
Post a Solution
Location for diode?
Hello thunder, I have the same problem w/the convergence and the warping. How can I find the location of the broken...
Post a Solution
How to determine which part?
Hello Babylooch..how did you determine what needed to be replaced? We have the convergence problem w/a warped screen as...
Post a Solution
rca distorted picture -
I have the same problems reported by others on my tv. I saw you suggested the part 259638 for it. Is this a part I can...
Post a Solution
tv has no sound
Wnen tv is turned on, ther is no sound playing. It worked fine earlier this morning.
Post a Solution
Sounds like a fan is running in the back...
Today we first noticed a sound coming from the back of the tv that sounds like a fan running - it's pretty loud....
Post a Solution
rca tv
rca rear projection tv turns off by itself/hessing sound
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size52 inch
Digital TV StandardHDTV · HDTV - HDTV receiver is integrated.
Technical Features
Parental ControlV-Chip
Sleep TimerWith Sleep Timer
Commercial SkipWith Commercial Skip
Dimensions
Depth22.75 in.
Height51.75 in.
Width48.75 in.
Weight148.7 lb.
Warranty
Overall Warranty1 Year
Tube Warranty2 Years
Connectors
Headphone JackWith Headphone Jack
Rear Input ConnectorsComponent x 1 · S-Video x 2 · DVI x 1 · Audio (RCA) x 4
Front Input ConnectorsComposite x 1 · Audio (RCA) x 1 · S-Video x 1
Rear Output ConnectorsComposite x 1 · Audio (RCA) x 2 · Subwoofer Output
Display Capabilities
Aspect Ratio16:9
Broadcast Format Supported1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Remote Control
Remote ControlMultibrand
Audio Features
Audio OutputVariable / Fixed
Audio TypeStereo
Sound LevelerWith Audio Leveler
MTS StereoSAP / MTS Stereo
Screen Text
OSD LanguagesEnglish · French · Spanish
Channel LabelsWith Channel Labels
Image Quality
Comb FilterDigital 3-Line
Adjustable Color Temp.With Adjustable Color Temperature
Speakers
Number of Speakers2 Speakers
Speaker Power2 x 10 Watt
RCA Contact Information
Main support number580-634-0151
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
