Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Dec 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture flutters and distorted
Picture flutters and is distorted for 1 to 4 hours after turning set on. Always clears up.
Anonymous
Level 3:
  • Master 505 Answers
  • Posted on Dec 06, 2008
Anonymous
Master
Level 3:
Answers
505
Questions
Helped
120922
Points
1367
Capacitors going bad on your DM or FMT board. Very difficult to replace, but Mits does a rebuild on the chassis. I recommend talking to your Mits service center and getting the rebuild done.
How to do you fix a sanyo 46 lcd HDTV with a half screen distortion?
Shouldn't have bought a Sanyo. It's not the same company it once was. It's toast.
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
1helpful
Philips 60p8342 projection tv 1)Color distorted, whitish and dull 2)Picture bowed at top and bottom 3)Set turns off by itself 4)I can't turn on set unless its been off and unplugged for many hours and then...
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Picture has shadowing or ghost like images
This unit is getting distortion form the video circuits, most likely capacitors or resistors causing distortion to the input or output circuits. This problem could be caused by a bad video amplifier also ,which is distorting the signal. This problem needs to be checked with an oscilloscope to follow the signal path and find the source of the distortion. Usually this is best handled by a service center. If the unit is still under warranty call this number for Insignia customer help : 1-877-467-4289. If the unit is not under warranty, you should take it to a service center and have an estimate of the problems and repair costs. You can find parts for this television at the Best Buy parts website. Just google it and put in the number of your television and it will list all available parts and prices. You can also call this number for Best Buy parts : 1-888-237-8289. Hope this helps you with your problem.
TV turns on and then, after a few seconds, picture changes to "double vision".
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
1helpful
2answers
Picture bounce or flutter
In case there is a loose connection and the convergence board is not damaged. This is what I did and worked out "perfect".
My Mitsubishi HDTV Medallion 1080 has been with us for about 7 years.
The TV started showing distortioned colors and images and even when I used the convergence options from the main menu, it would not show clear images until it would be working for around an hour or if we would hit it until the image would fix. It got worst over the time at a point that it would require 2-3 hours working and several punches and kicks.
No doubt dust has done it's job, well, a vacum with a brush end can help resolve the problem.
1. Make sure the TV is off and disconnected from power.
2. Remove the rear cover at the back (it is clear wood colored and is at the lower part of the cabinet)
3. Using a vacum with a brush end, vacum all the dust that you will find. Be cautious not to hit the components and do not or apply preassure while doing the work
4. On the left side, you will see a card over a mother board, make sure to vacum it well and that it is well inserted in the slot (I did apply some preassure to make sure it was fully inserted)
It took me around 15 minutes and my tv is working like NEW.
While you are removing the dust with the vacum, you may want to vacum the 3 lenses as well, again, using the vacum, no need to clean them with a cloth. I saw a thick layer of dust over them and could remove it easily with the vacum.
Hope this will work for you.
Al
Yamaha RX-V861 Low frequency "flutter" after turning on
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
Diagonal lines moving from bottom to top
sample of a line diagnally from bottom to top of page.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
