Mitsubishi WD-65733 65 in. HDTV Television
Problems with Mitsubishi WD-65733 65 in. HDTV Television?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WD-65733 65 in. HDTV...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Mitsubishi WD-65733 65 in. HDTV Television RSS Feed
View More Results for Mitsubishi WD-65733 65 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WD-65733 65 in. HDTV Television RSS Feed
Answer
I have a WD-Y577 it keeps shutting off on its own and the red lamp light comes on. What's wrong?
Answer
need diagram to clean inside of Mitsubishi WD-65733 I need a picture to see what I will be cleaning.
Answer
i have audio but no picture on my 65733 projection tv. Is it the lamp?
Answer
I have a wd65733....When I turn the set on, I get a picture then about 30 seconds later it will shut... (More)
Answer
The green timer button blinks for couple of seconds before the lamp button comes on.There is a... (More)
Answer
My Mitsubishi WD-65733 does not turn on. Green Timer light keeps blinking all the time. Can you let... (More)
Find a Manual
Mitsubishi WD-65733 65 in. HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen... written by Ecollier2012
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the... written by Ecollier2012
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for WD-65733 65 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Mitsubishi WD-65733 65 in. HDTV Television
Write a review:
Rate this product:
Would you recommend the WD-65733 65 in. HDTV Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Mitsubishi WD-65733 65 in. HDTV Television
Product MPN
MPN
WD-65733
Key Features
Screen Size
65 inch
Digital TV Standard
HDTV · HDTV - HDTV receiver is integrated
Projector Technology
DLP
Display Resolution
1920 x 1080 pixels
Combo Features
Playable File Formats
JPEG
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC · QAM
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 1080p (HDTV)
Broadcast Format Displayed
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV) · 1080p (HDTV)
Remote Control
Remote Control
Multibrand
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp
With Adjustable Color Temperature
Audio Features
MTS Stereo
SAP / MTS Stereo
Technical Features
Picture in Picture
Without PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Rear Input Connectors
Component x 2 · S-Video x 2 · USB Port
Front Input Connectors
Component x 1 · USB Port
Screen Text
OSD Languages
English · French · Spanish · German · Italian · Portuguese
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
15.4 in
Height
39.5 in
Width
58.2 in
Weight
78 lb
Warranty
Overall Warranty
1 Year
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
