Mitsubishi Diamond WD-65831 65 in. HDTV Television
Problems with Mitsubishi Diamond WD-65831 65 in. HDTV Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Mitsubishi Diamond WD-65831 65 in. HDTV...
Troubleshooting and Support
Solved Problems for Mitsubishi Diamond WD-65831 65 in. HDTV Television RSS Feed
View More Results for Mitsubishi Diamond WD-65831 65 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi Diamond WD-65831 65 in. HDTV Television RSS Feed
Answer
i have a 65 inch mitsubishi hd 1080 diamond series. When I watch a movie on my blu ray player the tv... (More)
Answer
i have a mitsubishi 65" Diamond series. remotes have quit working. also upon power up the... (More)
Answer
Power light just flashes - can;t turn on. tried unplugging - did not resolve
Answer
I have a diamond mitsubishi and the Tv picture is concave and rainbow and the numbers or type of... (More)
Answer
Mitsubishi Diamond 55'' Rear Projection - Will not power on; no light, no clicking, just dead. will... (More)
Find a Manual
Mitsubishi Diamond WD-65831 65 in. HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Mitsubishi Diamond WD-65831 65 in. HDTV...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.... written by toddg
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi Diamond WD-65831 65 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Mitsubishi Diamond WD-65831 65 in. HDTV Television
Key Features
Screen Size
65 inch
Digital TV Standard
HDTV · HDTV - HDTV receiver is integrated.
Projector Technology
DLP
Display Resolution
1920 x 1080 pixels
Dimensions
Depth
19.8 in.
Height
40.8 in.
Width
58.5 in.
Weight
99 lb.
Connectors
Rear Input Connectors
S-Video x 2 · Composite x 2 · RF x 2 · HDMI x 2 · FireWire x 2 · G - Link
Front Input Connectors
S-Video x 1
Rear Output Connectors
Audio (RCA) x 1 · DVI x 1 · Component x 3 · HDMI x 2 · Audio (RCA) x 7 · Coaxial Digital · Optical Digital · G - Link
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV) · 1080p (HDTV)
Broadcast Format Displayed
Remote Control
Remote Control
Multibrand
Illuminated Remote
Illuminated
Audio Features
Audio Output
Fixed
Audio Type
Stereo
Sound Leveler
With Audio Leveler
Image Quality
Adjustable Color Temp.
With Adjustable Color Temperature
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
