We have 20" LT20s only used 3 weeks out of the year. Sound no picture,its an 2006 fix or throw...
(More)
We have 20" LT20s only used 3 weeks out of the year. Sound no picture,its an 2006 fix or throw away? kind of ashame!Been sitt'in for a year.Olevia LCD
37 in flat screen insigna does not start with remote or side buttons. If power is turned off, there...
(More)
37 in flat screen insigna does not start with remote or side buttons. If power is turned off, there turned back on tv worked properly. This is a daily problem.
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
This information was found on the Insignia website www.insignia-products.com Under the technical information for the insignia television model:...
This information was found on the Insignia website. www.insignia-products.com under technical information for the insignia television model number ...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
