RCA P46921 46 in. Rear Projection Television
Problems with RCA P46921 46 in. Rear Projection Television?
Troubleshooting and Support
Solved Problems for RCA P46921 46 in. Rear Projection Television RSS Feed Post a New Problem
I hear a sound like a shortcircuit on...
Thanks for the answer, yes i have low experience in TV reparation but i dont have the schematics for this TV, if you...
1 Solution
RCA Projection TV model #p61926
Pictuure is not focused, tv screen curves the picture with half upside moon at the bottom and half moon at the top. Each...
1 Solution
RCA 46" Screen replacement with...
I paid $75 for this TV because it had a cracked screen (lower right corner) and the screen was bright fuzzy orange....
1 Solution
clean the light guns
I have an RCA P46731AT Serial # 437380188. What are the best steps to take to clean the light guns and improve the...
1 Solution
color is very dark
The color of the TV is very dark and the brightness and contrast are to te max. Are the 3 projection lamps too old to...
1 Solution
RCA P46921. Just changed flyback.
Hi Sir, I just personally changed the flyback in my TV. Before I had this problem however the picture was clear ,now...
1 Solution
RCA P4677OCK
I HEAR A CLICKING NOISE IN THE BACK OF THE TV AND THE TV WLL NOT TURN ON. WHAT IS CAUSING THIS AND WHAT IS THE SOLUTION
1 Solution
Unsolved Support Problems
Unsolved Problems for RCA P46921 46 in. Rear Projection Television RSS Feed Post a New Problem
RCA P4677ock
Tv was working fine and then turned itself off and won't turn back on. Power cord is plugged in and wall outlet has...
Post a Solution
P46921 - RCA Projection, And remote...
IT worked perfectly but it seams in gor reprogramed (the remote controler), anyones knows what code is for the RCA 46921
Post a Solution
remote
I have tried several rca universal remotes including the guide plus and none of them seem to work, is it possibly the...
Post a Solution
cleaning
Can someone explain how to remove the front screen to clean .Does it come out?
Post a Solution
colour
I have this model and the colour is not very good , also the picture is ok but not very clear?
Post a Solution
RCA P46921 red, blue, green out of line
red, blue, green do not line up?
Post a Solution
RCA Projection TV with no colors
HI, I have an RCA projection TV that has no color. The screen show colors only on TV set up.
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size46 inch
Audio Features
Sound LevelerWith Audio Leveler
Technical Features
Picture in PictureWith PIP
RCA Contact Information
Main support number580-634-0151
Sponsored Links
Loading problems.
Top Experts
Ask Me
ctf1800 Guru
43 solutions
Ask Me
Terryfic Guru
31 solutions
Ask Me
who BoB Wiz
5 solutions
Repair Service
Find Projection TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
