Received from a friend. worked fine at their place. transported to ours and now the colors are...
(More)
Received from a friend. worked fine at their place. transported to ours and now the colors are really off. We tried to adjust them manually, but nothing seems to work. Sometimes the pciture is too red, then it's too blue. whites glow way too bright.
I have a 60P8342 projection tv. When I turn it on you can watch it for about 2hrs then it shuts...
(More)
I have a 60P8342 projection tv. When I turn it on you can watch it for about 2hrs then it shuts itself off as if it gets hot, then after it cools down about an hour later it will turn back on but doesn't stay on long. Is there anything that I can do myself to fix it.
all the bright lights like sunlight,any reflecting lights give off a high glow dulling the rest of...
(More)
all the bright lights like sunlight,any reflecting lights give off a high glow dulling the rest of the screen.
I tried to look through your problems/solutions section but it isn't available. we have a phillips...
(More)
I tried to look through your problems/solutions section but it isn't available. we have a phillips 60p8342 TV, it started out with needed the red/blue to be converged about every other day for aprox. 3-5days and then the picture had a green tint to it. We shut it off and tried again the next day but now when the TV is turned on, we get no audio/video, only the red power light comes on and the initial sound of the TV upon power up. Is there any kits to fix this?
Turned tv off with remote last evening and when tried to turn on this morning, on light did not come...
(More)
Turned tv off with remote last evening and when tried to turn on this morning, on light did not come on nor did the tv
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
