Mitsubishi WD-62725 62 in. Rear Projection HDTV-Ready Television
Problems with Mitsubishi WD-62725 62 in. Rear Projection...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WD-62725 62 in. Rear...
Troubleshooting and Support
Solved Problems for Mitsubishi WD-62725 62 in. Rear Projection HDTV-Ready Television RSS Feed
View More Results for Mitsubishi WD-62725 62 in. Rear Projection HDTV-Ready Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WD-62725 62 in. Rear Projection HDTV-Ready Television RSS Feed
Answer
I replaced the lamp and now have horizontal lines streaming from top to bottom? It also had a line... (More)
Answer
Picture is flickering constantly.. just started. All channels, all sources.
Answer
when the tv gets plugged in the green light under the word timer flashes rapidly and the tv wont... (More)
Answer
my mitsubishi wd 62725 turned off and will not turn back on. It has a green blinking light, the... (More)
Answer
with out warning the red light indacating lamp failure came on last night,still had sound. Today I... (More)
Answer
fast green blinking light on timer.tv will not power on. tried system reset numerous times.... (More)
Answer
Analog video sources are distorted Over air digital signals are clean
Find a Manual
Mitsubishi WD-62725 62 in. Rear Projection HDTV-Ready Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Mitsubishi WD-62725 62 in. Rear Projection...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.... written by toddg
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi WD-62725 62 in. Rear Projection HDTV-Ready...
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Mitsubishi WD-62725 62 in. Rear Projection HDTV-Ready Television
Key Features
Screen Size
62 inch
Display Format
1080i (HDTV) · 720p (HDTV) · 480i (SDTV) · 1080p (HDTV)
Digital TV Standard
HDTV-Ready
Projector Technology
DLP
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Remote Control
Remote Control
Standard
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Surround Sound Type
Dolby Digital / AC3
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Rear Input Connectors
Component x 2 · S-Video x 2 · Composite x 2 · 1 x D-Sub (RGB PC) · RF x 2 · 1 x RS-232C · Audio (RCA) x 6 · RGBHV (BNC) x 1 · HDMI x 1 · FireWire x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1 · Firewire (IEEE 1394) x 1
Rear Output Connectors
Composite x 1 · RF x 1 · Audio (Mini Jack) x 1 · DVI x 1 · Audio (RCA) x 3
Memory Card Slot
CompactFlash Card · SD Card · SmartMedia Card · MMC Card · Memory Stick
Screen Text
OSD Languages
English · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
19.9 in.
Height
43.7 in.
Width
58.3 in.
Weight
165.5 lb.
Warranty
Overall Warranty
1 Year
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
