Home | Mitsubishi | Projection Televisions
Mitsubishi WD-52525 52 in. Rear Projection HDTV Television
Problems with Mitsubishi WD-52525 52 in. Rear Projection HDTV...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WD-52525 52 in. Rear...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Mitsubishi WD-52525 52 in. Rear Projection HDTV Television RSS Feed
View More Results for Mitsubishi WD-52525 52 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WD-52525 52 in. Rear Projection HDTV Television RSS Feed
Answer
I have diagnol lines running across after it has been on a few minutes.
Answer
suddenly and without warning the setup screen has changed on my wd-52525 and it doesn't have the set... (More)
Answer
Mitsubishi 52' dlp, 52525. wont come on, green light flashes 11 times. the power went out and this... (More)
Answer
There is a green static or noise going across the screen (right to left) and it is worse on the... (More)
Answer
Hi, I am hoping that someone here has seen this issue, or at least can point me to a site that may... (More)
Answer
My tv is throwing a blue flashing light that doesn't allow me to see the tv menu or do anything... (More)
Find a Manual
Mitsubishi WD-52525 52 in. Rear Projection HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen... written by Ecollier2012
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the... written by Ecollier2012
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Call this number recall or refund
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company... written by jrleopards
I Received Full Refund
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have... written by jrleopards
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for WD-52525 52 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Find an Expert
Meet our 4507 Projection Television Experts
budmrtn
#1: budmrtn
Rank: GuruGuru
Televisions & Videos ExpertExpert
Rating:  87%, 143 votes
Solutions:  689 (684 Votes in the last 30 days)
Experience: 30 Years of professional repair and design.
dmftrucker
Rank: GuruGuru
Rating:  87%, 402 votes
Solutions:  1582 (483 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
projdoc
#3: projdoc
Rank: GuruGuru
Rating:  94%, 598 votes
Solutions:  1178 (455 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Nomodo4u
#4: Nomodo4u
Rank: GuruGuru
Rating:  89%, 218 votes
Solutions:  423 (416 Votes in the last 30 days)
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
cene765
#5: cene765
Rank: GuruGuru
Rating:  89%, 369 votes
Solutions:  709 (398 Votes in the last 30 days)
Experience: More than 5 years attempt with printers, computers and all office equipment
justaskjoe
Rank: GuruGuru
Rating:  85%, 1979 votes
Solutions:  3806 (341 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
57 varieties
Rank: GuruGuru
Rating:  88%, 510 votes
Solutions:  1495 (340 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
localwonder
Rank: GuruGuru
Rating:  92%, 2766 votes
Solutions:  4891 (320 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
Chu3505
#9: Chu3505
Rank: GuruGuru
Rating:  85%, 389 votes
Solutions:  1254 (297 Votes in the last 30 days)
Experience: I was an engineer for 20 years.I repair tv all models for 15 years for friend shop,was my hobbies.
techbuster
#10: techbuster
Rank: GuruGuru
Rating:  89%, 487 votes
Solutions:  1100 (275 Votes in the last 30 days)
Find a Warranty
Specifications for Mitsubishi WD-52525 52 in. Rear Projection HDTV Television
Key Features
Screen Size
52 inch
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Digital TV Standard
HDTV
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC · ATSC
Remote Control
Remote Control
Learning
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Surround Sound Type
Dolby Digital / AC3
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
S-Video x 2 · DVI x 1 · Composite x 2 · 1 x D-Sub (RGB PC) · RF x 2 · 1 x RS-232C · Audio (RCA) x 6 · Component x 3 · RGBHV (BNC) x 1 · HDMI x 1 · FireWire x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1 · Firewire (IEEE 1394) x 1
Rear Output Connectors
Composite x 1 · Audio (RCA) x 2
Memory Card Slot
SD Card · SmartMedia Card · MMC Card · CompactFlash Card Type I · Memory Stick
Screen Text
OSD Languages
English · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
17.4 in.
Height
37.2 in.
Width
49.6 in.
Weight
132.4 lb.
Warranty
Overall Warranty
1 Year
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
