Vtech Cordless 6041 Phone Logo
Posted on Apr 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I check the voicemail? - Vtech Cordless 6041 Phone
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vtech Master 102,366 Answers
  • Posted on Sep 24, 2011
Vtech Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444313
Points
622693
The 6041 isn't an answering machine. If you subscribe to a voicemail system offered by your telephone company, contact them for information. If you have an answering machine connected to your phone, consult its documentation.
I have a panasonic home phone want to remove the voice mail sign and light flashing
To remove the voicemail indicator and stop the flashing light on your Panasonic home phone, you can try the following steps:
1. Access the voicemail system: Dial your home phone number from your Panasonic phone or another phone and let it ring until it goes to voicemail. Enter your voicemail password or follow the prompts to access your voicemail messages.
2. Listen to and delete all voicemail messages: Check your voicemail inbox for any new or saved messages. Listen to each message and follow the instructions to delete them. Ensure that your voicemail box is empty.
3. Exit the voicemail system: Once you have listened to and deleted all voicemail messages, exit the voicemail system by following the prompts or hanging up the call.
4. Reset the phone: Disconnect the power adapter from the back of your Panasonic phone base unit. Wait for about 30 seconds and then plug the power adapter back in. This will perform a reset on the phone and clear any residual indicators.
5. Check the voicemail indicator: After the phone has rebooted, check if the voicemail indicator is still active or if the light is still flashing. If the issue persists, proceed to the next step.
6. Disable visual voicemail feature (if applicable): Some Panasonic home phones offer a visual voicemail feature that may trigger the voicemail indicator and flashing light. To disable this feature, consult the user manual for your specific model and follow the instructions to turn off the visual voicemail function.
7. Contact Panasonic support: If you have followed the above steps and are still unable to remove the voicemail indicator or stop the flashing light, it's recommended to contact Panasonic customer support for further assistance. They can provide specific guidance based on your phone model and help troubleshoot the issue.
Remember to consult the user manual for your Panasonic home phone model as the steps and features may vary slightly.
this video might help
My dora 6040 wont make phone calls it goes to voicemails
If it is like Chris H said, that when your phone is receiving calls it straight up goes to voicemail you need to check your voicemail. What time did you put there? Does the voicemail go off after 5 sec or after 20 sec. You need to check that
Aug 25, 2021 • Cell Phones
How I access voice mail from another phone?
    1. You can access your iPhone voicemail from any phone by dialing your iPhone's number from the other line. After calling your number, toaccess your voicemail: On AT&T: Interrupt the voicemail greeting by pressing the star key (*).
      How do I access my iPhone voicemail from another phone? ' The ...
      www.iphonefaq.org/archives/971987
    Feedback
  1. How to Check Voicemail from Another Phone: 8 Steps
    www.wikihow.com > ... > Managing Telephone Messages
    wikiHowHow to Check Voicemail from Another Phone. It is hard to imagine, but sometimes you don't have your cell phone on you. Yet you still need to check your ...
How do I check voicemail
VoiceMail is not a function or feature of the VTech cordless
phones.
VoiceMail is an option offered by some (not all) telephone
service providers, and each of those who do offer the feature
employ specific procedures unique to themselves.
Check with your Telephone Service Provider to see if you
have or can get a VoiceMail service activated and how to
go about using it.
Per the CS6114 User Manual, the display indication
"New Voicemail" will be removed from the cordless phone
handset when you have accessed the providers' VoiceMail
system and played/cleared the messages.
If the alert display persists, it can be cleared from the handset
by the following (tested on my own cs6114 phone):
press [menu]
scroll to "Settings"
press [select]
scroll to "Clr voicemail"
press [select]
display reads "Reset VM Icon?"
press [select]
phone will (chirp) press [off ] [off ]
Set up voicemail on iphone5s
It's simple. Just follow below steps.
To record voicemail on iPhone, you have to first set up Voicemail and then record voicemail message by following these steps:
    1. Tap on Phone > Voicemail;
    2. Usually, you will be guided to automated voicemail system and you can simply follow voice prompt to set up Voicemail. If not, you have to follow these steps:
    a. Click "Set Up Now". You will be required to enter password. Tap password and then click "Done". Re-tap again and click "Done". Please keep in mind that password should be between 4-6 digits in length.
    b. Click "Custom" to record voicemail. Activate "Record" to start recording and tap "Stop" to finish recording voicemail. After you finish recording voicemail, tap on "Save".
    For more details, check: How to Record a Voicemail on iPhone
1helpful
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
When I press the voicemail button to get the messages instead of going right into the voicemail messages, it just keeps ringing. The display says "Ringing ST26"
The voicemail system is not answering. Often on Toshiba systems the voicemail is a seperate PC based unit. Try locating voicemail and check for power or reboot. If this is a PC based voicemail, a common failure is the voiceboards in the PC that allow calls to be answered by the voicemail. If you detrermine that voicemail is running but just not answering, a bad voice board is the likely cause.
Voicemail doesn't work
I would check with your cellular provider to make sure that they kept your voicemail when you purchased the new phone.
Voicemail password
call your provider and ask for it and they'll give it to you.. gud luck man
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
