20 Most Recent AT&T Avaya / Lucent Merlin BIS-34D 34 Button Phone - BLACK Questions & Answers
http://www.radiomanual.info/schemi/YAESU_HF/FT-847_user.pdf
AT&T Lands... | Answered on May 06, 2020
actually you can get the manual for free at manuals lib.com
AT&T Lands... | Answered on Jan 27, 2020
They aren't repairable. Buy a new matching set of three. Technology improves each year.
  • VTech CS6719-15 DECT 6.0 Cordless Phone.
  • Vtech CS6719-2 DECT 6.0 Dual Cordless Phone.
  • Panasonic KX-TGC222S Answering System with Two Handsets.
  • AT&T CRL82312 Cordless Answering System with 3 Handsets.
  • Gigaset-E630A Splash and Shock Resistant Cordless Phone.
  • Vtech DS6421-3 Cordless System with 3 Handsets.
More items...
Top 10 Best Cordless Phone of 2019 + Editors Pick - Omnicore
https://www.omnicoreagency.com > best-cordless-phones
AT&T Lands... | Answered on Dec 26, 2019
Is this just for your home or do your neighbours have the same problem? I hope I can help you further, a few more details would help me be able to help you.
Regards Jem
AT&T Lands... | Answered on Sep 22, 2019
Do you hear tones when you press the buttons to dial?Many phones have the option to dial by pulses instead of tones. Make sure your phone is set to tones.
AT&T Lands... | Answered on May 13, 2019
REREAD THE INSTRUCTION MANUAL . IT TOOK ME SEVERAL TRIES TO DO MINE . 40 YEARS AGO
AT&T Lands... | Answered on Mar 26, 2019
If you need the remote access code for the answering system, then the original (default) access code is given in the manual on page 50 (page 53 of the PDF) and on 55 (page 58 of the PDF). See the manual online at https://att.vtp-media.com/ecp/documents/product_Product/364/UserManual/5977/SL82118_manual_i10.pdf . Unfortunately, if the remote access code has been changed, the default code will not work. As far as I know there is no way to reset the SL82318 remote access code to the factory default remotely. See page 50 of the manual to reset the phone's access code when you are using the handset. When you use the handset and start to change the code, the current remote access code will be announced first.
Any voice mail system would be accessed using the phone number and codes from your telephone service provider. This information will not correspond to the answering system of the SL82318.
I hope this helps.
AT&T Lands... | Answered on Mar 16, 2019
Reverse the polarity of the phone wires.
-Some phones are sensitive to this; others do not seem to mind.
I believe you should reverse the red and green.
AT&T Lands... | Answered on Feb 03, 2019
Check your ground wire where the phone line comes into the junction box outside your house. It is either loose or corroded. It should be clean and clamped to a ground stake or water pipe like for an outdoor hose faucet. Check both ends of the wire. Without it, the phone system's impedance is so high that it will receive the 60 Hz hum from any electrical appliances around the house that are within a few feet of a line on an extension phone, answering machine or even an extension phone outlet wire running through a wall. These make great receiving antennas. good luck.
AT&T Lands... | Answered on Jan 04, 2019
That is not possible. Deleted means gone for good.
AT&T Lands... | Answered on Dec 31, 2018
If you delete the greeting you recorded, it should default to the canned response.
AT&T Lands... | Answered on Dec 05, 2018
Take the back cover off your phone and remove the battery. You will find the IMEI on the label there.
AT&T Lands... | Answered on Oct 30, 2018
AT&T Avaya / Lucent Merlin BIS-34D 34 Button Phone - BLACK Logo
2 questions posted
Top AT&T Lands Phones Experts
Ekse
Marvin
Marvin
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
AT&T Lands Phones
  • AT&T Lands Phones
Most Popular Question
phones acting as voicemail box full
  • Lands Phones
