Question about Vtech DECT 6.0 Digital Cordless Phone
How do I check voicemail
Model # CS6114. Don't know how to check voicemails
Posted by Tamara Phay on
Art Cacella
    Passionate:
    Visited the website for 10 consecutive days.
  • 186 Answers
VoiceMail is not a function or feature of the VTech cordless
phones.
VoiceMail is an option offered by some (not all) telephone
service providers, and each of those who do offer the feature
employ specific procedures unique to themselves.
Check with your Telephone Service Provider to see if you
have or can get a VoiceMail service activated and how to
go about using it.
Per the CS6114 User Manual, the display indication
"New Voicemail" will be removed from the cordless phone
handset when you have accessed the providers' VoiceMail
system and played/cleared the messages.
If the alert display persists, it can be cleared from the handset
by the following (tested on my own cs6114 phone):
press [menu]
scroll to "Settings"
press [select]
scroll to "Clr voicemail"
press [select]
display reads "Reset VM Icon?"
press [select]
phone will (chirp) press [off ] [off ]
Posted on May 13, 2016
5 Related Answers
Anonymous
SOURCE: Don't know how to answer voicemail
we have voicemail thru our phone service so we hit *98 then punch in our password.hope this helps
Posted on Nov 27, 2008
Anonymous
SOURCE: cant get voicemail
call your own phone number, and once it asks for the password type in the last 4 digits of your phone number.
Posted on Mar 04, 2009
Anonymous
  • 3 Answers
SOURCE: how do I SET UP MY VOICEMAIL ON MY VTECH , LIGH IS FLASHING
After you heard the message (suggest you to call your phone company to get your voicemail access code if you don't know your code), then press the "menu" button on the phone, and scroll down to find the "CLR VOICE MAIL" and press OK.
Posted on May 23, 2009
masteria
Rohit Asthana
  • 355 Answers
SOURCE: Cannot get voicemail.
Download a manual here , may be this will help out..
http://safemanuals.com/user-guide-instructions-owner-manual/VTECH/CS5111-_E
Posted on Aug 18, 2009
Anonymous
SOURCE: Vtech Model 6042 Voicemail Indicator Light Does Not Work
How to set up a voice mail indicator on vtechcs6219-2
Posted on Mar 06, 2010
How do you check your voicemail on a VTech cordless phone
The cordless phone pictured appears to be a VTech CS6114
and an Answering Machine System is not part of this phone.
** BUT ** an Answering Machine System is not the same
as "VoiceMail" anyway.
do have a VoiceMail service activated and how to go about
using it.
Per the CS6114 User Manual, the display indication shown,
"New VoiceMail", will be removed from the cordless phone
press [menu]
press [select]
press [select]
press [select]
phone will (chirp)
press [off ] [off ]
Jun 14, 2015 | Vtech Lands Phones
My vetch phone shows "new voicemail". how do I delete this
To clear the "New Voicemail" display from the handset
is a slightly different procedure for each model of cordless
phone.
Try the following (tested on my own cs6229 phone):
press [menu]
press [select]
display reads "Turn Off Indicator?"
press [select]
Or, this one (tested on my own cs6114 phone):
press [menu]
press [select]
press [select]
press [select]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Feb 13, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
How to change number of rings on VTect cordless CS6114-11
The CS6114-11 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 30, 2014 | VTech Communications CS6114 - cordless...
How do i changse number of rings on my vtech
Jul 30, 2014 | VTech Communications Vtech Cs6114 -...
Cs6114 how do you check your voicemail on this device?
The CS6114 isn't an answering machine.
You may have voicemail on the system offered by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 09, 2013 | Vtech DECT 6.0 Cordless Phone with Digital...
How do i check my voice mall on my Vtech phone Model number CS6114
The CS6114 isn't a voicemail system. You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 10, 2012 | VTech Communications CS6114 - cordless...
How do I check voicemail on my vtech cs6114?
The CS6114 isn't an answering machine. If you have a separate answering machine connected to your phone line, consult its documentation. If you subscribe to a voicemail system offered by your phone company, contact them for information.
Oct 26, 2011 | Lands Phones
How do i retrieve my voice mail model cs6114
The CS6114 isn't an answering machine. Please consult the documentation for whatever answering machine or voicemail system for instructions.
Aug 30, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do i listen to voicemail on my CS6114 cordless Vtech phone?
The CS6114 isn't a voicemail system. If you have messages on the voicemail system provided by your telephone company, contact your telephone company for instructions on accessing their voicemail system.
Aug 23, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
What is the number for the voicemail system on a vtech 6.0 cs 6114 ??? OR How do i answer the voicemail message????
Jun 04, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech DECT 6.0 Digital Cordless Phone Logo
183 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Bruce Robin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
