20 Most Recent Apple iPhone 5S Questions & Answers
Here are some methods to help if you don't have enough space on iCloud.
Method 1. Delete Photos/Videos from iCloud
One of the biggest data hogs to take up your iCloud storage space is the photos and videos. iPhone/iPad will automatically back up all your videos and photos to your iCloud. Therefore, deleting photos and videos from iCloud will free up iCloud storage a lot.
1. Tap on Setting > iCloud > Storage. Then tap on Manage Storage.
2. And then tap on This iPhone.
3. Under the Backup options, you will see Photo Library option, set the slider to OFF position.
4. Tap on Turn off & Delete to delete all photos and videos from iCloud.
Method 2. Delete Data & Documents
If you still find that there is no enough storage on your iCloud, you can try to delete these app-related documents and data to free up iCloud storage.
1. Go to Settings > iCloud > Storage > Manage Storage.
2. Select an app under "Documents & Data".(The first one genrally takes the biggest storage)
3. After selecting the app, tap the "Edit" tab in the upper right corner and then select the specific document to remove, or tap the "Delete All" tab.
Method 3. Close Unnessary Backups for Apps
If there are entire apps that you don't need to backup, you can do so by following the steps below to fix not enough iCloud storage for your iOS devices:
2. Select the device you want to manage the backup for.
3. Under "Backup Options", toggle apps off that you do not want to sync to iCloud.
Some other guides will be introduced in the following article. Please feel free to check them out.
How to Fix Not Enough Storage on iCloud for Your iPhone iPad
Apple iPhone 5S | Answered on Jun 24, 2020
Hi Alex jenkins, there are two ways to backup your iPhone, backup using iCloud or iTunes. The best way of backing up your *entire iPhone data is by using iTunes. For more info on how to backup iPhone, visit the link below:
How to back up your iPhone iPad and iPod touch
https://support.apple.com/en-ph/HT203977
-josh
Apple iPhone 5S | Answered on Apr 06, 2020
It's simple. Just follow below steps.
To record voicemail on iPhone, you have to first set up Voicemail and then record voicemail message by following these steps:
    1. Tap on Phone > Voicemail;
    2. Usually, you will be guided to automated voicemail system and you can simply follow voice prompt to set up Voicemail. If not, you have to follow these steps:
    a. Click "Set Up Now". You will be required to enter password. Tap password and then click "Done". Re-tap again and click "Done". Please keep in mind that password should be between 4-6 digits in length.
    b. Click "Custom" to record voicemail. Activate "Record" to start recording and tap "Stop" to finish recording voicemail. After you finish recording voicemail, tap on "Save".
    For more details, check: How to Record a Voicemail on iPhone
Apple iPhone 5S | Answered on Jul 08, 2019
Apple won't allow to save data into SIM with iPhone. However, you still can reach this aim through certain indirect methods. Just follow below steps.
This can be a good way if you only need to transfer a few number of iPhone contacts to SIM card. You can do this by sending emails of the contacts. You can email the contacts one by one to your Android smart phone, and then import them to the SIM card in the Android phones. The detailed steps may better help you.
Step 1. Go to the Contacts app on your iPhone, find those contacts you would like to transfer to SIM card. Then tap "Share Contact" and share these contacts via email.
Step 2. Download the vCards you just shared via email on your Android phone. Go to Contacts app on Android phone, then you can choose "Import from USB storage".
Step 3. Go to Contacts app to check if contacts have already been imported to your Android phone. Then go back to "Import/Export contacts" again, this time you should tap "Export to SIM card". Of course you need to put the SIM card into the Android phone before this step.
With this way, you can copy a limited number of contacts from iPhone to SIM card. This isn't a direct and simple way to transfer iPhone contacts to SIM card. You need the extra help of an Android phone, and you also need to type emails one by one to import SIM contacts. Although, it is a good way to back up the contacts by coping them to SIM card, you can also use other backup methods to save the contacts, like use data backup programs or back up them to the cloud.
For more methods, check: How to Transfer Contacts from iPhone to SIM
Apple iPhone 5S | Answered on Jun 28, 2019
If you want to transfer data contacts from iPhone to pc, you can try iOS Assistant. With its help, you can easily access data contacts on iPhone and export them to pc directly via usb cable. https://www.coolmuster.com/idevices/transfer-contacts-from-iphone-to-computer-pc.html
Apple iPhone 5S | Answered on Jun 19, 2019
If you lose the contacts on your iPhone 5s, you can use a data recovery software to help you recover the lost files like contatcs, it is very useful.
And you need to launch the software on computer, then through the USB cable to link the phone with computer.
In the end, you can mark the deleted ones to recover on your iPhone easily.
How to Recover Deleted Contacts from iPhone 8 7 6S 6 5S 5
Apple iPhone 5S | Answered on May 16, 2019
The iPhone can be used to connect to the internet thru a wifi connection.
just open Settings and clic on Wifi. The available wifi networks will appear if there are some any, and you should be able to connect to one of them if given the correct password. Some stores and restaurants offer free (but slow) wifi that don't require a password. They may ask that you accept their 'Terms of use' which will show up when you use Safari the first time you try to access a website.
Apple iPhone 5S | Answered on Mar 11, 2019
To my knowledge, you can use the iOS Data Recovery to help you recover the deleted text message.
How to Retrieve Deleted Text Messages on iPhone 2018 update
Apple iPhone 5S | Answered on Nov 09, 2018
By attempting to access your ex-husbands phone you are breaking a number of privacy laws. Regardless of who has the device, or who owns it the data contained belongs to your ex-husband. Should he find out he could potentially prosecute you in a law court in most countries in the world (including USA, UK and Europe).
Apple iPhone 5S | Answered on Sep 27, 2018
If you synced your iPhone after you received that call and have not synced it since you deleted the call log then it may be possible to retrieve it by performing a restore on your iPhone and using the iPubsoft iPhone Backup Extractor.
Resource from:
How to Retrieve Deleted Call Log on iPhone 5 4S 4
Apple iPhone 5S | Answered on Dec 26, 2017
Hi, make sure you have a backup of all of your files in iCloud first and to do this from your iPhone, just go to Settings >> iCloud >> Storage & Backup >> then tap "Backup Now"..............You can now do a restore, via the Settings >> General >> Reset >> Erase All Content and Settings (This only applies if your iPhone is not Jailbroken, if your iPhone is Jailbroken, there's a different procedure for that) Once you're done with the restore, "Setup your iPhone" screen will appear and just tap on the "Restore from iCloud backup".
Apple iPhone 5S | Answered on Nov 15, 2017
Go to iphone setting - then passcode or touch id & passcode. now tap on change passcode and then enter your old passcode and then new passcode. And if you forgot your passcode and your ipod iphone disabled and you want to unlock disabled iphone ipad.
here is the detail procedure
First method you can restore your ipod. But this will erase all your data on ipod. So if you have recent backup then go for restoring ipod. For that just connect your ipod to computer- then open itunes. Make sure you have installed latest itune version otherwise update your itunes first. Now open itunes then find your ipod under deivce tab at the top left sidecorner. Click on your ipod icon. Click on summary and then click on restore.
You can also restore your ipod from old backup also. For that open itunesfind your ipod under device menu. Now select your ipod and then right click on your ipod the you will get options for restore from backup.Select restore from backup this will provide list of all your previous backup on that computer itunes. Now select your backup which you want to restore and then click on continue. Once your restoring is completed your ipod will shut down and then again restart your ipod it will take few minutes to start up. And it also asks few information about you. Once you complete all that procedure your ipod is unlocked which was disable or locked due to wrong passcode.
Apple iPhone 5S | Answered on Sep 30, 2017
click on it and hold it then try move it down.
Apple iPhone 5S | Answered on Apr 18, 2017
You could try a complete shut down on the iphone then restart as memory can get short. Hold down the power button until you see ' slide to power off', once its shut down power up again and try the game . If that doesn't work try reinstalling minecraft. Also, make sure your running the latest version of iOS. Hope this helps:)
Apple iPhone 5S | Answered on Mar 01, 2017
I have a iPhone 7plus, and I've had every iPhone that came out every year but I need a little more detail please?
Apple iPhone 5S | Answered on Jan 24, 2017
Apple iPhone 5S Logo
328 questions posted
Popular Products
Top Apple Cell Phones Experts
Marvin
Marvin
sandyp4ever
sandyp4ever
Level 1 Expert
Matthew Boulden
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
recover iphone messages
  • Cell Phones
