20 Most Recent
Vtech DECT 6.0 Digital Cordless Phone Questions & Answers
What does it mean by out of range or no power at
Maybe you handset was registered to another base at one time or another. The mmessage out of range will show up also if it cant see the base.If you have a DS6101 you can manually deregister the handset without having the original base it was registered too by doing the following steps:Called the manufactuer.... To do this enter on the handset you want to deregister:*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).This will put the handset back into the register mode.Hope this helps,James Pavicic Jr
Vtech Dect 6.0 says not registered. how do I
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
I forgot my PIN number to my voicemail.
You could go into your voice mail and press the prompts to set up your PIN. Voice mail will get you into your settings usually. Try long pressing the number 1 to access your voice mail.
If you already know how to access your voicemail, try using the last four digits of your phone number as your initial PIN. That is the way most phones used to be set up. If that works, then you can create a another PIN to your liking and no longer have to use the last four digits of your phone number.
How do I check voicemail
VoiceMail is not a function or feature of the VTech cordless
phones.
VoiceMail is an option offered by some (not all) telephone
service providers, and each of those who do offer the feature
employ specific procedures unique to themselves.
Check with your Telephone Service Provider to see if you
have or can get a VoiceMail service activated and how to
go about using it.
Per the CS6114 User Manual, the display indication
"New Voicemail" will be removed from the cordless phone
handset when you have accessed the providers' VoiceMail
system and played/cleared the messages.
If the alert display persists, it can be cleared from the handset
by the following (tested on my own cs6114 phone):
press [menu]
scroll to "Settings"
press [select]
scroll to "Clr voicemail"
press [select]
display reads "Reset VM Icon?"
press [select]
phone will (chirp) press [off ] [off ]
I am trying to forward my calls to my cell phone from my vtech dect 6.0 phone, how do I do that
That forward-to-another-number would usually be a function of the telephone company or service provider -- BUT the Vtech DS6522 and a similar AT&T phone do include a Bluetooth connectivity with an associated cellphone wherein the cellphone is the "service provider" and the Vtech handsets are "extensions" from the cellphone, a complicated scenario. See your model's manual ( it is available at www.manualslib.com ) and/or perhaps talk to your phone company. Good luck!
How do I set the number of rings?
These are instructions on how to set the number of rings before your iPhone goes to Voicemail. You can increase or decrease the amount of time your iPhone rings by following the simple steps below. Press the Phone icon in your iPhone's dock. Press to select Keypad from the tabs at the bottom of the screen.Jan 25, 2009
www.iclarified.com/.../how-to-set-the-number-of-rings-before-your-iphone...
