Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Anonymous Posted on Feb 16, 2011
How can i solve this problem alarm lamp (orange) blinking and display the screen E alternate with # 4 and # 2 for printer canon prima mp160
RockTheHood
Level 2:
  • Expert 176 Answers
  • Posted on Mar 09, 2011
RockTheHood
Expert
Level 2:
Answers
176
Questions
0
Helped
433878
Points
302
E42 22 Scanner error
check the cable from the scanner, it basically gives up and replacing it by
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
Eror p2
the web address for the manual is "http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp250#BrochuresAndManuals"
look for this document "mp250sosmwin110us.exe" install it and then look for the "troubleshooting" on the right side of the window and follow the instructions. the path is (MAIN WINDOW) >
Troubleshooting
An Error Code Is Displayed on the LED
Power Lamp Flashes Green and Alarm Lamp Flashes Orange Alternately
(go down the page until it says: Power Lamp Flashes Green and Alarm Lamp Flashes Orange Alternately )> then look for the error code. good luck!!sorry, the system is printing the same font as the book.
Can't get my color cartage to print on my canon prima mp160.
Hi there not know if it will work so you go to come back to let us know pleas.
Also if you are using the Refillable ink cartilages stop they always cause major issues
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)Note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.(it must be turn off)
then
Alarm light only on only on cannon MP160 (not Blinking)
Ok this may do the trick, can only try.Also if you are using the Refillable ink cartilages stop they always cause major issues
button pressing
then turn it on again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
5helpful
Power Lamp Flashes Green and Alarm Lamp Flashes 7 TIMES
Count how many times blinks orange lamp and check this error in this forum.
MP160 error message E5 and alarm light on
OK lets try this
button pressing
4helpful
4answers
Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
old marine
old marine
ZJ Limited
ZJ Limited
