Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon Pixma MP150 Error code E 42
The printer powers up but after a few whirring noises displays E-4-2. I understand from other help links that this refers to a scanner fault. The scanner light bar does move about 1" to the left before returning on power up. There's no light when this happens - should there be? Then the error code comes up, together with the amber warning triangle light and the on-off button light flashes. Any ideas please?
  • 2 more comments
  • aikido70 Jun 05, 2008
    The printer Canon MP160 powers up but after a few whirring noises displays E-4-2. I
  • cims_pm Jun 29, 2008
    and the on-off button light flashes. please help me
  • Mcgiwer Aug 18, 2008
    After power up and the startup procedure the screen shows E-4-2. additionally the alarm lamp is pulsing.
  • kenwzh Dec 17, 2008
Anonymous
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Posted on Mar 11, 2008
Anonymous
    Scholar:
  • 41 Answers
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Posted on Feb 11, 2008
  • Mcgiwer Aug 05, 2010
    My model don't want to go in the service mode. After releasing the power button the printer turns off instead of going into service mode.
elle2008
Hi, I had the error E 4 2 and finally figured it out! I opened the printer up (just normally like if you were replacing the ink cartridge) and then kinda pushed the thick white cable back into the right hand side of where the ink cartridges are and then it worked normally! The cable was just a bit lose I guess, it had gotten pulled out a little.
Posted on Mar 21, 2011
j6t_girl
    New Friend:
    Problem Solver:
How can i solve this problem alarm lamp (orange) blinking and display the screen E alternate with # 4 and # 2 for printer canong prima mp160
Posted on Feb 15, 2011
Error code E42
Error 42 indicates scanner failure. It is sometimes caused due to loose /
faulty scanner cable that connects scanner to motherboard.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 14, 2013 | Canon PIXMA MP150 All-In-One InkJet...
My Canon Pixma MP 150 printer has an error code of E27, waste ink absorber is full. Is there anything I can do to fix it? Or do I have to take it in to a service center? I don't want to pay more for...
Canon MP150 error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Aug 13, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Cannon mp150 printer error
sorry, i don`t actually know but i think you should just use genuine catridges
May 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Printer error code
You can try to reset it by follow this instructions
Mar 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My problem with my pixma 145 is there is an error "ink absorber i
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Mar 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printing problems
Please tell me what error codes you get
Nov 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Driver and troubleshooting
this is the link to download your mp150 printer drivers
http://www.canon-asia.com/index.jsp?fuseaction=support&country=IN
After installing the drivers the software will tell you the error report like paper jam, no paper, catridge ink low etc
Bye
Take Care
Apr 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon Pixma MP150
Hi Try
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Apr 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
5,809 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
