If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again. Printer Properties cannot be displayed. The print spooler service is not running. Printer cannot be removed. The print spooler service is not running. Windows cannot print due to a problem with the current printer setup. (When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE. 2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES. 3) Locate and highlight the PRINT SPOOLER on the list of Services. 4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Resolution:
Hi!
Resolution:
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 : * Start > run > services.msc > ok * Select the service name called print spooler from the list. * Check the status on the print spooler service, if it is stopped, then right click and select start or restart. * Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK ) In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok * Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler) * Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service) * Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Resolution:
SPOOL.SVC
Resolution:
SPOOL.SVC
1. Go to Start > Run and type in services.msc then press Enter.
2. In the window that opens find "Print Spooler" on the right
3. Right-click "Print Spooler" and select "Properties".
4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
5. Make sure the 2 text boxes underneath say "1" in them.
6. Click Ok until you are back at the Services window, close it and you're good to go.
7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
