Tip & How-To about Video Game Consoles & Games
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected to a router for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Troubleshooting
The built-in diagnostic of the Xbox can help with any falure.Navigate to the System area of the Xbox Dashboard, select the Network Settings menu option, then select Test Xbox Live Connection to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message:
    Technical configuration error. Please contact Xbox Customer Support.
This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure.
If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.
Note You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.
Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.
Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.
If you're using the black adapter with two antennas:
  • No light: The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  • Green: The adapter is connected to a wireless router, gateway, or access point.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Red: The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console.
  • Flashing red: There is a problem. The adapter might be experiencing a hardware failure.
Configure your wireless settings Go to My Xbox, and then select System Settings.
Select Network Settings.
Select Configure Network.
  1. On the Basic Settings tab, select Wireless Mode.
    Note If Wireless Mode is still not available, there might be a problem with your hardware.
  2. Select Scan for Networks.
  3. Select your wireless network name.
    If your wireless network is not listed, try either of the following:
    1. Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select Specify Unlisted Network, and enter your wireless network name and security type.
  4. Enter your wireless network password, and then select Done.
  5. Press the B button on your controller, and then select Test Xbox LIVE Connection. If you successfully connect to Xbox LIVE, you'll see this screen:Choose Yes when you are prompted to update the console software.
Video Game Consoles & Games Logo
cant connect to xbox live
What you need:A high-speed Internet connection such as cable A router, gateway, or wireless access point (WAP) that is compatible with Xbox LIVE. An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only) Instructions: On your console, go to My Xbox, and then select System Settings. Select Network Settings. Select the name of your wireless network. Enter your wireless network password. Select Yes if you are prompted to update your console software. When you successfully connect to Xbox LIVE, your screen will look like this:
how do you get connected to xbox live
What you need
  • A high-speed Internet connection such as cable or DSL
  • A router, gateway, or wireless access point (WAP) that is compatible for xbox live
  • An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only)
Configure and test
Next you need to configure your wireless settings and test your Xbox LIVE connection. The steps vary slightly, depending on your console's software.
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select the name of your wireless network.
  4. Enter your wireless network password.
  5. Select Yes if you are prompted to update your console software.
how to get an internet connection for xbox live
Hello award ward,
To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible
with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
michael34
im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Tips:
internet
First you need an internet connection, wireless or network cable.
For wireless:
You need the XBox 360 wireless adaptor.
Follow instructions to plug it in, then turn on console.
Go to the Dashboard.
Go to Console Settings.
Then Network Settings.
Then Search for a Network.
When you find your network, select it.
If you have a network code, such as WEP, enter it when prompted.
Now, whenever you turn on your XBox and have the wireless adaptor plugged in, it will automatically connect to your network.
For cable:
Plug in the cable to your console at the back.
Then follow above steps if it doesn't automatically connect you.
To play with mates, you need to purchase an XBox Live Gold Membership.
To do this, you must create an account after connecting to the internet.
To create an account:
Dashboard
Create Account
It will ask you to set up XBox Live and to pick a name.
Pick your name and connect it with a Windows Live account such as hotmail.
Follow steps to input information.
Payment can be automatic to a credit card number or, you can purchase XBox Live Membership Cards at most electronic stores, and input the codes.
You get one month free trial just for signing up.
Now to play:
Find out your friends' gamer tags or XBox Live name just as you made yours.
Push the XBox Guide button in the middle of your controller.
Select Friends.
At the top, add friends.
Input their gamer tag.
When they accept your invite/request, you can invite them to chats and games.
Pick your game, follow the instructions to play a multi-player game over XBox Live with your friends.
Have fun.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
