Our printer is not printing-it is only (faintly) printing about 2 inches on the left side vertically. We have put in new ink cartridge checked paper size and nothing seems to work! Please help! The printer is a Canon imageclass MF8180c.
The smudges on the side of the paper is most likely a piece of something rubbing against the paper just after the printer puts the ink on the paper. Inspect as much as possible the path that paper takes. Look at rollers. Anything that grab the paper. Look for ink and dust build up. As for the vertical lines. Could be several things. I you haven't used you printer for awhile the ink in the nozzle could of dried up. Most new printers have a nozzle cleaning function. Try that it a couple of times. See if that helps. If it shows any sign of change after that, it dried up ink. It's a hassle to try to get the ink flowing again. I normally just to replace the cartridges. Let me know if this helps or not.
Run a "half test".
Put paper in the manual feed tray(tray 1).
Print anything.
Watch the paper. When it gets about 1/2 way into the printer, open the top cover.
Remove the toner. Look down at the paper. Do you see the "usual" line?
If yes, replace the toner cartridge.
If no the fuser is probably bad.
I think extra ink make stripes. to remove those stripes follow the instruction:
1.open the top cover of your printer
2.find out a sponge that are in the left side of the printer bottom.
3.put off it and wash it well by using cold water. And fit it again. Then move the head left from right. Now put a soft tissue upon the printer head clining unit, then move the head again from left to right sothat printer head can reduce from ink. then move the head again and put off the tissue. Then on your printer your printer remain work.
thank you.
shohagtush
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate. Have some test on it at Printer Maintenance. I'm sure 100% works on it. Good luck!
I had almost the same exact problem. Left the printer unused for a month or so, came back, no black ink being printed, even though the level was still sufficient.
What I did, was boiled a small pot of water, and held the black ink cartridge over the steam, about 3-4 inches above the boiling water, for 2 increments of about a minute. Try not to burn your hand or cook the cartridge lol. I wiped the cartridge head with a piece of paper periodically until I noticed a good bit of dark ink on the paper, then gently wiped the condensation off of the cartridge with a paper towel so as not to put a wet cartridge back in my printer. Put it back in the printer and voila!
Works great so far, although I can't vouch for the long term effects of this solution. I did look at the cartridge a bit later to make sure it wasn't leaking, and it wasn't. You have to steam it the right amount of time. I would guess that the printer cartridge head will inevitably dry out again with limited use. I'm hoping that it will keep working though haha. Hope this helps anyone else with this problem.
