You can print in only black and white by choosing the grayscale option in the print properties, but you still have to have ink in each of the color cartridges. Even if you are only printing black, the machine will not let you print if any of the colors are out.
Replace the empty ink cartridge, and then select "grayscale" to print only in black and white.
SOURCE: changing printer cartridge
hi, if you have put a new cartridge it has a protection tape stuck on the nozzel, we have to remove it before installing it.the yellow light indicates no or bad cartridge, may be this should solve the problem.. let me know..
SOURCE: Align Print Cartridge Failure
hello..
You may be need to buy a new color cart., becuase the allignment page depend on the Yellow color when it become to scan..
or you can pring any allignment page from a friend and put it in the scanner instead that one you printed out....
Hope it's work
Yasser
SOURCE: ink cartridge light keeps blinking BEWARE SPAM NUMBER 1-800-532-4187
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
SOURCE: lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
