Was this a sata or IDE drive (sata has a small cable while IDE has wide cable connector going to the motherboard of your computer) try first to change the cable. check also if the unit is detected in the cmos setup of your motherboard(usually when you press delete during power up you can go to the cmos setup of your computer) check the standard cmos setup and see if the DVD is detected). if all of this fails then i think you need to replace the drive.
