20 Most Recent LG GSA-E10L (8801031212552) DVD±RW Dual Layer Burner Questions & Answers
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
check the leads that attach to this external dvd you might have to physically unplug the leads for this dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
LG GSA-E10L... | Answered on Sep 05, 2011
I think it is a blue ray disk
LG GSA-E10L... | Answered on Aug 21, 2010
u must download it from lg site.u need the setup file for istallation
LG GSA-E10L... | Answered on Aug 11, 2010
hi mcasey82,
Yes lg external dvd drive would work with just about any latest linux distribution, if your user account is a member of the plugdev linux groupthe drive will automatically appear on the desktop after you plug the drive from the usb slot
you can verify the plugdev group members by issuing a command cat /etc/groups from the command terminal
[email protected]# cat /etc/groups | grep plugdev
if your current username is not a member, you add by issuing a usermod command
[email protected]# usermod -g plugdev username
LG GSA-E10L... | Answered on Mar 26, 2010
The SMPS unit is down which needs to be replaced/Repaired.
LG GSA-E10L... | Answered on Jan 26, 2010
Search google with the name of your hardware and download the software for the LG or go to the manufacturer site
LG GSA-E10L... | Answered on Jan 15, 2010
You should find the answer here.
http://www.dvd.reviewer.co.uk/info/multiregion/
LG GSA-E10L... | Answered on Jun 21, 2009
No, the dvd player is totally separate. you will not need to tune your TV, just plug the DVD player in via a scart or an HD socket, and run through your channels till you find which one it is on :)
LG GSA-E10L... | Answered on May 16, 2009
TRY THE MANUFACTURES WEB SITE..
WINDOWS USUALLY SHIPS WITH DEFAULT DRIVERS THAT SHOULD WORK FOR MOST DEVICES (MEDIA)
LG GSA-E10L... | Answered on Apr 13, 2009
download latest driver u can google for the latest driver
LG GSA-E10L... | Answered on Jan 23, 2009
do you have the latest driver installed? u can google for the latest driver.
Unfortunately, most drivers for linux are already included in linux when you install it. Most of the devices I have ever tried with linux works when I plug it in. I don't usually have to install drivers. Depending on what linux you have, the device should pop up in devices mounted or media. I would do a search for the device first because I'm almost certain linux can detect it. I think that you just can't see it because it probably didn't pop up on your desktop. Start from root and look under places like /mnt or /cd0. I bet you will find it. If you can't then let me know and I'll walk you through.
LG GSA-E10L... | Answered on Jan 19, 2009
Try the manufacturers web site for support and downloads.
http://us.lge.com/support/download/search.jhtml
LG GSA-E10L... | Answered on Dec 06, 2008
Try reseating your IDE cables. or Assuming you have powered down and restarted and then click start button\control panel\system\hardware tab\device manager and see if there are any yellow/red flags that might give you some information.
If all else fails go to the cd drive in device manager and uninstall the driver and follow directions, choose automatic install when it gets there. Then do the same with the cd/dvd and see if things work.
LG GSA-E10L... | Answered on Oct 18, 2008
This could be a driver issues or is it software .
Remove device and software first reboot then reinstall
if you have the disk then reinstall should be straight forward.
Try plugging in the device ,
and use the device manager for the drivers update install.
(while in device manager-select device rightclick and update)
This should fix your issue,
If problem persists,
refer the problem to the retailer you purchased from,
should be still under wanrantee if its a new one,
there supplier should honor the warantee no problems....
You may need to provide proof of purchase for warantee.
LG GSA-E10L... | Answered on Aug 08, 2008
try to clean the lense with a special brush cd.ussualy this works
bye
LG GSA-E10L... | Answered on Jun 15, 2008
TRY A -R DL, or try a slower speed or different media type. some media are not as good as others and readers have problems reading them. I SUGGEST you use a different media or try a -R or a +RW
LG GSA-E10L... | Answered on Feb 20, 2008
LG GSA-E10L (8801031212552) DVD±RW Dual Layer Burner Logo
Popular Tags
28 questions posted
Top LG Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
GSA LG
  • GSA LG
Most Popular Question
need make lg dvd receiver ht503 region
  • Computers & Internet
