20 Most Recent Lite On LightScribe (HP640VI) (HP640VI) Burner Questions & Answers
Lg cd ver 1.04
what sort of problems are you having ? Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps you
12/27/2011 9:53:32 PM • Lite On... • Answered on Dec 27, 2011
I have no manual for
Most DVD burners require a power cable as well as a USB cable. Check the slots on the back to be sure, check for any holes that are round with a pin in the middle, or possibly three different holes in some cases. If you see a slot like that, you need your power cable.
5/4/2011 9:30:20 PM • Lite On... • Answered on May 04, 2011
I dont know where is
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver or scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall then click start all programs open windows explorer click on my computer you should see your usb device navigate to the audio files the select the audio files right click copy and then paste them into your computer or select all media files click and hold the cursor and drag and drop them into usb divice or right click and select send to you your usb device hope this helps
1/20/2011 8:23:05 AM • Lite On... • Answered on Jan 20, 2011
How do I find out which version of light scribe is
hi right click the light scribe icon, then go to properties then click find location, look for the light scribe icon in the folder , then right click that then properties, and view the version...hope that helps
7/1/2010 9:32:26 PM • Lite On... • Answered on Jul 01, 2010
Can I connect this device to a Mac computer or is
You should be able to connect every Optical drive to mac and i guess you can fit it in, becuase both mac and windows ,and linux are using same hardware systems, just in different connections.
Please rate my solution! =)
Sincerely
Aleksandar Adzic
4/16/2010 7:09:58 PM • Lite On... • Answered on Apr 16, 2010
Need a operators manual
Dear sir in fact i diged out the internet searching for the manual that you mentioned above but nothing i got ... but there is a good point i found the HP640V manual on the address http://search.hp.com/query.html?sh=1&charset=UTF-8&la=en&qt=HP%20dvd640v%20DVD%20Writer%20640%20vi
and you can open a similar product catalog to find out the answer for your questions .... from the sit www.HP.com thank you and good luck
12/23/2009 12:34:04 AM • Lite On... • Answered on Dec 23, 2009
How do I activate the option to burn an 8.5GB
That option would be set in Roxio, not the drive itself.
Make sure that your machine meets the requirement for speed and memory required to write DVD's at this density.
12/22/2009 6:09:50 AM • Lite On... • Answered on Dec 22, 2009
Instructional manual
Go here http://www.lightscribe.com/ It's not a manual but should have all the info you need. Don't forget you need special DVD's to make it work
9/19/2009 8:53:00 PM • Lite On... • Answered on Sep 19, 2009
Burns blank
Try different software. Download nero trial at www.nero.com
6/6/2008 3:03:44 AM • Lite On... • Answered on Jun 06, 2008
P4B533 doesn't load up windows. reset BIOS,swap memory. Green lite on MB, CPU fan runs. long beep
1. check for keyboard stuck keys. 2. Clean memory and Memory slot well and fix back memory. 3. check capacitors close to the memory slot if they are not damaged, if damaged replace the capacitor with a new capacitor.
8/13/2022 2:07:04 PM • Lite On... • Answered on Aug 13, 2022
2answers
Driver missing for lite-combo sohc-4836k
please will you till me vinaly AC97 ADIO CODE 10 IS NOT INSTALL HOW CAN I UPDATE THIS DRIVE
5/15/2022 1:06:51 PM • Lite On... • Answered on May 15, 2022
I want to move old HDD drive from broken down LiteOn 5045A DVD recorder to replacement DVD recorder machine...
cart before horse.!WELL BAD NEWS (TOPIC) HDD.the drive is 21 years old tech. 2001it is not any kind of modern standard HDDit is PATA(IDE) NOT MODERN SATA (SERIAL ATA)SO ONLY RELIC OLD DRIVES CAN WORK HERE.or run old 20+ hdd tests that take a week to finish(now you see why SATA was born, PATA stinks)and worst is the DVD burner is not a desktop or laptop standard drive and worse yet PATA againthe old DVD drive, replacement can be hard.lite-on does not support old things, gee most makers do not after 17 year old.also read here, and see how spare parts actually workin this old burner systemhttps://forum.videohelp.com/threads/325208-Liteon-LVW-5045-replace-DVD-drive-project-startedwhat your are attempting is not easythe huge problem is fireware in the devicemany not allow larger HDD over 160GB new.or may not allow all makers of the drive to work at all.is not that DVD DRIVE, PATA DRIVE, NOW 100% OBSOLETETHE SAME FIRMWARE RESTRICTIONS (NOT DOCUMENTED ON EARTH i MIGHT ADD) WILL NOT ALLOW SOME DVD DRIVES BY OTHER MAKES.... LOOKING NOW AT OTHER WORKING ON THIS OLD BEAST WHAT DO I SEE IN their nice PHOTOSL (tech eyes win)the hdd iS NOT SATA IT IS 20 YEAR OLD PATA(IDE) JUNK.FINDING GOOD USED PATA DRIVES IS HARD..NEW ONES ARE SOLD AT SCAPLERS PRICES, (AS expected)the DVD drive is clearly custom made by SONy for Liteon..HERE IS DVD PROOF OF NON STANDARD DRIVE(FIT)45ad81af-aef0-4368-8bdf-55959c725f31.jpg
5/15/2022 11:40:43 AM • Lite On... • Answered on May 15, 2022
I have a zipspin c120 pro, the Lite-on ihap 122 drive is bad, will a ihap 124 by lite on work in its place?
Yes. DVD drives are intercompatable for the most part.these days. just pull out the old one, install the new one, and the OS will install the drivers and it will work just fine.
7/11/2019 7:19:29 PM • Lite On... • Answered on Jul 11, 2019
5answers
Can I Install GDMSS Lite on Windows 10 Laptop?
In case you have a good PC, you can easily install it using Bluestacks. Here are the steps:
  1. Download Bluestacks
  2. Search for "GDMSS Lite"
  3. Proceed with installation.
Source: Download gDMSS Lite for PC on Windows 7 8 or 10 10Downloads com
10/2/2018 4:34:20 PM • Lite On... • Answered on Oct 02, 2018
0answers
No sound comeing out next to volume control yellow lite on says overloaded
Rule number 1 in pc troubleshooting and electronic troubleshooting is to always power down the device and turn it back on to see if that doesn't help, if the problem persists. . . you can call us on your fixya app and we can help you fix your issue with no problem. Hope this helps ?? If you need further help, I’m available over the phone at https://www.6ya.com/expert/brant_4c68df22dda524c2
9/21/2017 12:22:55 AM • Lite On... • Answered on Sep 21, 2017
Lite On LightScribe (HP640VI) (HP640VI) Burner Logo
Popular Tags
10 questions posted
Top Lite On Computers & Internet Experts
Steve Pack
Steve Pack
Larry Ng
Larry Ng
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Computers & Internet
Most Popular Question
no manual
  • Computers & Internet
