Posted on Jan 07, 2010
Ricoh MP 5500 changes 8.5 x 11 documents to legal size on scan.
Have a Ricoh MP 5500. When 8 1/2 x 11 documents are scanned, the scanned image has white space at the bottom, which makes the documents look like they were legal size. What would cause this? Customer also states that when making copies, same issue occurs.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
3524
Points
12
Verify that the paper size shown on the display matches the size and direction of the paper in the respective trays, make sure paper side guides and rear backstop are tight against paper
Ricoh MP C5502 Color Laser Multifunction Printer - Ricoh. What could cause paper not registering on the MP C5502 cutting top part of the image please?
Question edited for a lot more clarity and toss in some CAPS.
Question moved to maker category.
Printer set to wrong size paper.
Computer word processing program set to wrong size.
For example Letter size paper in Printer and Legal size in the Settings of what is saying to print the document. The paper is too small.
Scanner image is askew
Base on your explainination it seems like, this is because of your setting in MP Navigator, the image may not be scanned properly. In such a case, it is necessary to match the settings in MP Navigator to the document. please do the following. 1) Match the type of the document on the platen glass to the document type set in MP Navigator. For example, when scanning a color photo, select Color Photo in Document Type of MP Navigator. 2) Match the size of the document on the platen glass to the document size in MP Navigator. For example, when the document size is A4, select A4 in Document Size of MP Navigator. (Memo) Auto Detect is set in Document Size as the default.
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
3helpful
How do you get the Canon Pixma mp500 to scan?
Scanning images,
About Scanning images
You can scan images from the machine to a computer without printing them and save them in popular formats. Scanned data saved on your computer can be processed using image processing software. Furthermore, you can use the OCR (Optical Character Recognition) software to convert scanned paper documents to text data.
* Before scanning
Before scanning images, confirm the following :
- Are the necessary software (MP Drivers and MP Navigator) installed ?
If the software is not installed, install it.
- Does the document to be scanned meet the requirements for an original to be set on the Platen Glass ?
- Is the machine connected to a computer correclty.
Confirm that the connection between the machine and the computer is physically secure.
Scanning Methods.
A) Scanning Using the MP Navigator
MP Navigator enables you to scan in documents loaded on the Platen Glass and view images saved on your computer or on a memory card. Scanned documents can be previewed and easily printed and edited according to your needs.
You can use the supplied application softwares to edit or print the document you have scanned.
Windows : Double-click the [MP Navigator 2.0] icon on your desktop to launch MP Navigator.
Mac : Select [Applications] from the [Go] menu, then double-click the [MP Navigator 2.0] icon to launch MP Navigator.
You can launch the following application software from the MP Navigator.
* Easy-PhotoPrint (Photo Printing)
* ArcSoft PhotoStudio (Photo image editing)
* ScanSoft OmniPage SE ( Converting scanned document to text)
- This application software may not be supplied with teis machine in some country.
Note : If you did a [Custom Install] and only installed the MP Driver and MP Navigator, these application software were not installed and thus cannot be launched. To launch any of the above application softwares from MP Navigator, do a [Custom Install] once again to install them.
For detailed operations of the MP Navigator, refer to the Scan Guide.
B) Scanning Using the Operation Panel of the Machine
You can scan documents to your computer by using the Operation Panel.
Important : Do not insert or remove USB cables when scanning images with the machine connected to a computer, or when the computer is at sleep or standby mode.
*If you are using Windows XP
The program selection screen is displyed the first time you press [Color] or [Black] on the machine.. Specify the [MP Navigator 2.0] as the application software to use, check [Always use this program for this action], then click [OK]. From the next time, MP Navigator is automatically started.
*When using Mac OS X
For the machine to start scanning when [Color] or [Black] is pressed, you need to set MP Navigator as the starting application software in Image Capture under [Applications] of Mac OS X.
1) Press [ON/OFF] to turn on the machine.
2) Load the documents on the Platen Glass.
3) Select the scan option.
a) Press [Scan].
The scan operation selection screen is displayed.
b) Use Up or Down arrows to select the scan operation, then press [OK].
Scan standby screen is displayed.
Save to PC : The document is scanned and saved.
Save as PDF file : The document is scanned and stored as a PDF file.
Attach to E-Mail : The document is scanned, and the image is attached to an e-mai using the e-mail application software.
OPen with application : The document is scanned and displayed on the registered application software.
4) Press [Color] or [Black].
The document is scanned. The settings configured from MP Navigator apply when scanning.
Important : If with some types of original the position and size of the image is not scanned in correctly, please refer to the "Selecting the Behaviour of the Operation Panel with Mp Navigator " in the Scan Guide (on-screen manual). and change the MP Navigator [Document Type] and [Document Size]] to match those of the original being scanned.
Note : The operation to be performed after scanning the document depends on the scan operation setting you have selected in step 3. For details on how to modify the operation settings, refer tp the Scan Guide on-screen menual.
C) Scanning from an Application Software
You can scan an image from TWAIN-or- WIA (Windows XP only) complaint application software and handle the scanned image in the application software. For detailed operations, refer to the Scan Guide (on-screen manual).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
7helpful
2answers
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
2answers
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
11helpful
Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
19helpful
7answers
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
