Televison & Video Logo
Posted on Jan 02, 2010
The color blue looks like it makes the Picture double vision.
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Jan 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
26317
Points
50
Its a convergence problem. You can get complete parts and instructiosn for this fix from TvRepairKits.com. They put together a kit for this. I used them for a convergence problem recently and they helped me fix my set.
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
2helpful
My tv looks like it has double screen....for example a picture of a tree....right next to it would be another tree....double vision...
This is not a LCD tv,It a DLP tv.This tv have a problems known as Convergence problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the convergence board must be change to fixes 3D pictures,shadows colors pictures and Green,Blue,Red colors misaligns,don't matches up to form a good picture.The shop will u $300-350 for parts and labors.
2answers
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Blue at top of my screen and showing double
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
My IQC50H94W Zenith projection TV has double vision...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
TV turns on and then, after a few seconds, picture changes to "double vision".
*Screen Looks 3-D
*Colors wont align
Model 43FDX01B double vision with red ark across bottom . and no user manual.
*Screen Looks 3-D
*Colors wont align
2helpful
Samsung HCP4752W double vision
*Screen Looks 3-D
*Colors wont align
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
2answers
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
