20 Most Recent Samsung PCL5415R TV Questions & Answers
SAMSUNG PCL5415
If the sound on your DLP TV is out of sync with your picture and the TV is not connected to a home theater system, a Samsung technician can adjust the sound sync function on the TV so that the sound and picture are in sync.
To arrange a service call to adjust the sound sync function, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864).
11/11/2019 1:45:36 AM • Samsung PCL5415R... • Answered on Nov 11, 2019
I have a 10 year old Samsung TV model PCL5415R that is taking longer and longer to turn on when off for extended period for example overnight. Started with a few minutes now up to 10 minutes and I ha
Wrong answer! This set doesn't have a dedicated power board so its not an option to replace the board but I'm able to give a some help that should get the set operating again, this is a very common problem for your model TV, try this, after its sat overnight to where you have issues with it coming on put a hair dryer on the air fins in the back of the tv and turn it on low for about 10 mins, then unhook the hair dryer and try to turn the TV on, I'm quite sure it will come on, what is going on is it has some low grade capacitors imported from China that are failing, if you know how to solder its easy to see what caps are bad as they will bulge out on the end away from the leads, you can order them about anywhere for a few cents each but stay away from the Chinese imports, if your unable to solder then you would need to take the set in for repair but it may not be worth the cost. One word of caution, the larger capacitors in the TV can hold a charge for several hours so if your going to work on it and are comfortable doing this let the set sit for about a day before attempting the repair...Good luck.
2/23/2018 2:51:19 PM • Samsung PCL5415R... • Answered on Feb 23, 2018
0answers
Will not adjust or focus correctly and black lines horizontaly
Check and replace the CRT base connecting socket. It is faulty. The component can be located at the CRT base card. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. http://electronicshelponline.blogspot.com/
1/25/2014 6:24:29 AM • Samsung PCL5415R... • Answered on Jan 25, 2014
Convergence board
A bluish picture is not a result of its bad convergence board. Check its video output card, for any loose solder terminals or damaged component/s. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
1/4/2014 8:55:16 AM • Samsung PCL5415R... • Answered on Jan 04, 2014
Screen is the color blue?
That isn't convergence that does that. There are "screen" trimmers, if someone has messed them up you can get all one color, but the usual cause is the picture tube going bad. The screen trimmers are on the PC board on the gun (narrow) end of the CRT. Some trimmers are color drive and others are color black level, or "screen". Don't adjust the color drives, it is a delicate balancing act to get them right. Find the one labelled blue and turn it down. If all you can get is too dark, turn the red and green up, just enough to see a dim color haze in a blank picture. Balance them out so the haze is gray. Then turn them all down just a hair so the screen is just black. Then try a picture. If you can't get gray on a blank screen then go to the high voltage transformer (the one that can kill you if you touch the wrong part) and adjust the "screen" control on its side up (it adjusts all the colors together). If you still can't get gray, one or more of the color guns is weak, and you may as well chuck it. Of course it could also be a bad blue drive transistor, but fixing that takes more expertise than you can get from a forum. Actually, just getting the TV open and propped up so it doesn't fall over is a job in itself...
1/4/2014 3:53:00 AM • Samsung PCL5415R... • Answered on Jan 04, 2014
manual
Picture is not bright looks grey
if you are watching a local channel tried to move in other channel just to ensure if the same issue, if the same the cause is with in the tv. if just only in some channel might have problem in the channel program.
12/7/2012 4:58:14 AM • Samsung PCL5415R... • Answered on Dec 07, 2012
Blue lines on screen
Go to a unused video input and examine the screen----if you see blue with slightly curved trace lines the blue screen control for the set is set just a bit too high.
12/4/2012 1:40:04 AM • Samsung PCL5415R... • Answered on Dec 04, 2012
Sound don't work
Check its speaker first. If it is OK, check and replace damaged component/s in the audio output circuit.
12/1/2012 2:52:30 PM • Samsung PCL5415R... • Answered on Dec 01, 2012
HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
11/4/2012 4:37:24 PM • Samsung PCL5415R... • Answered on Nov 04, 2012
Red and blue colors are way too vivid! What is the problem?
Check for any loose solder terminals at its video output card. This card can be located on the neck of the picture tube. Most of the components in it will heat up while TV works. Repeated heating and cooling, might make solder terminals to get loose. Resolder all suspected solder terminals by applying a little more solder. Visit the site refered here, and surf though. you might get details from here, I'm sure.
For more details type in this site name "Electro-help" (DO NOT copy and paste the site name from here. Doing so may lead you to wrong place) to search box of your search engine [not in the address bar of your browser], and press "Enter".
It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
You can locate this site, either at the bottom part of first search page, or at the top of second.
Detailed descriptions are there to help you.
6/8/2012 2:25:17 PM • Samsung PCL5415R... • Answered on Jun 08, 2012
Tv was turning on and off last night now it wont tturn on what is it!??
Is the model number listed here correct or not? A answer depends on it being correct or not.
6/1/2012 3:50:57 AM • Samsung PCL5415R... • Answered on Jun 01, 2012
Volume takes off by its self
If the volume is going up on its own etc I can provide answers to that--let me know with the "make a comment" tiny button on this page what is happening.
3/26/2012 5:50:06 PM • Samsung PCL5415R... • Answered on Mar 26, 2012
2answers
Double Vision
My Dad had a Hitachi rear projection with same problem blue and red were fine green was out of allignment and could not fix. Problem was the acual projector inside TV the cost for repair was more than TV was worth went out bought plasma.
2/19/2012 3:45:21 AM • Samsung PCL5415R... • Answered on Feb 19, 2012
Samsung hdtv, I have sound but no picture. This
Have you try watching using a DVD player on your t.v if doesn't try watch on it using a DVD player but if still it doesn't have a picture but only sound perhaps there is a problem with your HDTV.
7/1/2011 7:13:28 PM • Samsung PCL5415R... • Answered on Jul 01, 2011
Televison & Video Logo
Popular Tags
73 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
  • Samsung Televison & Video
Most Popular Question
convergence board
  • Televison & Video
