Washing Machines Logo
Posted on Jan 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag washer model LAT9306AAE won't come on - replaced blown fuse in machine & it blew again right away.
David Mcintosh
Level 2:
Sergeant:
  • Expert 222 Answers
  • Posted on Jan 01, 2010
David Mcintosh
Expert
Level 2:
Sergeant:
Answers
222
Questions
6
Helped
54221
Points
512
Fuses are there to protect from overheating and further damage to the appliance and/or wiring. A blown fuse is seldom ever the root cause of a problem... It is a symptom of a short or overload somewhere else in the circuit.
Check wiring to be sure there are no bare wires showing or shorting out against each other or the frame of the machine. Check that drive and pump motors turn freely (with power cord unplugged).
Your problem is NOT the fuse alone. Replacing it without correcting the root cause will result in yet another blown fuse.
I need to know where the wires goes on a maytag washer model # LAT9306AAE After replacing The lid switch?
If you are referring to the switch itself, you can connect the two wires, one on each side of the switch. It doesn't matter which one goes on either side.
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Fuse blown on Maytag washer
Could have been a surge dont think its anything to worry about ....run and keep an eye on it ....
1helpful
Washer not spining burn smell
belt burrt out advise new belt or new machine
2helpful
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
Fuse blew on my Maytag washing machine. 1 amp only and others blow. Time to buy new or service?
yes.you can buy the switch assembly unit. it gets short and the fuse blows out.
Washer was in fill cycle and stopped
You've got a short circuit somewhere in that electrical circuit.
First, unplug the washing machine.
Replace the fuse. If it doesn't blow immediately, then there is likely a short in the washing machine, and from what you describe, it's in the motor.
If it blows, then there is something wrong in that circuit, and you can likely rule out the washing machine. Check all devices on that particular circuit, of which there can be a number of plugs.
4helpful
2answers
My Maytag Model# LSG7806AAE Seriel# 15951872UW washer won't fill with water. I advanced the switch and it goes on when you get to the rinse and spin, but still no water.
After having a repair guy quote me $450 to fix this problem, I took it on myself. I first changed the lid switch as the repair suggested. No luck. Next, I changed the washer timer. Still no luck. Next, I disconnected the water tube and filled the washer with water ( a step I wish I had done first) and turned on the machine. The machine spins, drains, etc but still didn't fill. I changed the water valve. Still no luck. Finally, I changed the 50 cent fuse in the front left corner of the washer unit. Success! The fuse was the problem. The washer now fills correctly.
2answers
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
