Have only had for 3 days, was working perfectly. This morning, thought I had a dead battery, but when I tried to charge it NOTHING happened and it won't turn on!! He;p please?
I know this sometimes happens with these smart phones; one day they just up and quit.
You could try a fresh battery, and check your charging source.
Mine did something similar a couple days ago - I thought it was charging all night long, and in the morning when I went to turn it on... nothing. It ended up being my charging cable, it wasn't putting any juice to the phone.
Try using someone else's battery in your phone and/or your battery in their phone and try charging it and turning them on. If your phone turns on now, then its something wrong w/ the battery, if not... then its something wrong with your phone. Is there any possibility that it got wet? If so, take the battery out immediately (although its probably way too late after all the attempted charging), pour some rice into a small tupperware or other sealable container, snug your phone into the rice, then bury it completely in more rice and seal the container and LEAVE IT ALONE for at least a couple days. After u take it out and plug it in... go do something away from the phone for a bit... cuz it sometimes will take a while of looking like nothing is happening. I don't know what the notification light is like on that phone. But on mine, after probably 20 minutes of nothing while charging... the charging light started to flash (indicating that it is charging, but not yet ready to be turned on), once the light was solid on, turned the phone on no problem.
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died. To fix it, kick start the charging process. Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process. If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers. Hope it helps? Success.
check the voltage on the battery with a volt meter, it should be around 12.6 to 13 volts, if not charge battery with a charger, after charge try to start vehicle, if the vehicle starts use your volt meter at the battery again, the voltage should be around 14 to 14.5 any lower and the battery isn't being charged and the alternator should be checked and or replaced to solve the problem..
clean terminals charge battery if it goes dead battery is probably toast .put volt meter on terminals while running should read 14.7 volts if not probably dirty magneto seek professional help
had the eact same thing happen on my diesel and it turned out to be the alternator which had fried oine of the batteries.... you could put a charge on them and it would run for a week or ten days and then nothing.. clean the cables charge it up and it would go again... finally it just stop taking the charge and I look deeper and replaced the batteries ran fine for two weeks then dead again... alternator finally finished itself off... problem had been a little intermittent till then.. good luck
hey buddy just do one thing.. open the metal cover removing the 4 philips screws.. and then remove the battery then reinsert the battery and try.. it should work ... i had the same thing few days back.. it was charged and in my pocket when i tried to listen to it the damm thing wont switch on .. so i removed the batter and put a LED to the terminal to check power and inserted it back it and valaaa it hot and running again..
