My maytag top load washer is constantly going out of balance during the rinse and spin cycles. The machine is level and appears to sit properly, what might the problem be?
Check the inter tub ring you should hear water when you spin it by hand if you dont hear water replace the spin tub balnce ring it must be cracked or has a hole in it and leaked out the fluid this is a counter balancer when it gows into the spin cycle h Tech AL Wojo
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle.
You should start by checking the balance shocks .
