Tools & Hardware - Others Logo
L
Leee Posted on Oct 04, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It started getting too loud.. what should I do
Lelo gigi was almost silent but now it started making too much noise from the shaking/vibration
ADMIN Andrew
Level 3:
Top Expert:
  • Tools & Hard... Master 66,975 Answers
  • Posted on Oct 04, 2022
ADMIN Andrew
Level 3:
Top Expert:
Answers
66975
Questions
Helped
5089081
Points
379905
Question moved from Cars and Trucks
Contact them and get the machine serviced.
https://www.lelo.com/contact-us
My fridge started getting really loud when it cycles on, and seems to have a vibration when running
If it ismaking a steady noise, the motor that runs the defrost timer may be making noise. I f the timer motor is making a loud noise, then you should replace the timer.Vibration noises are often caused by dishes or containers vibrate on a shelf inside.
2answers
Lound vibration when running
Check gas control valve.
Good luck,
Marty
How to fix 7230 vibrating problem
took me ages as well. It was annoying me so much but now im free. Its not to do with sounds itself. You go to: Settings Sound and Display Make sure your phone is off silent and its on loud at this point. No vibrate either. Uncheck Haptic Feedback. Your done :-) I also unchecked audioble touch tones which are the noises it makes when your phone is on loud and you select an app and that. Oh and you can put your phone back to silent after youve done that if you want :-)
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Vacuum shaking badly right up to handle and very loud noise
Could be a broker motor retainer. There should be two motor retainers in this model, when one is borken, it causes the unit to
shake and vibrate.
Loud vibrating noise after warming up
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Explosive restart on almost new propane furnace
IF IN DOUBT AND NEW IT IS UNDER WARRANTY. THEY DO MAKE NOISE WHEN RESTARTING, BUT NO EXPLOSION
It makes a loud noise when I start it and continues to make the noise and vibrates and shakes when running
has the machine been knocked recently?if so,the belt may have come off,or the drum could be out of allignment.
Oct 15, 2009 • Dryers
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
