20 Most Recent
Taco Pumps Taco Red Baron In-line Circulator Pump 110-387 1/12b 115v 1725rpm Questions & Answers
How to fix Apsco 17 stapler with a detached spring?
To fix an Apsco 17 stapler with a detached spring, you will need to reattach the spring to the stapler. Here is a general process you can follow to do this:
- Unplug the stapler and lay it on a flat surface.
- Locate the spring and the area where it attaches to the stapler. This may be near the back of the stapler or on the underside.
- Using a small tool, such as a flathead screwdriver or a pair of needle-nose pliers, gently pry open the area where the spring attaches. This will allow you to access the spring.
- Hold the spring in place with one hand, and use the other hand to carefully attach the spring to the stapler. Be sure to align the spring with the correct attachment point, and apply gentle pressure to secure it in place.
- Once the spring is reattached, test the stapler to make sure it is functioning properly. If the stapler still does not work properly, you may need to consult a professional repair technician for further assistance.
