20 Most Recent Nokia 7230 Cell Phone Questions & Answers
Yes, mp4 is supported by nokia 7230
http://europe.nokia.com/find-products/devices/nokia-7230/specifications
Video codecs & formats
  • Video capture at up to 320 x 240 pixels (QVGA) at 15 fps
  • Video recording file formats: MP4 (default), 3GP (for MMS); codecs: H.263, MPEG-4
  • Audio recording file formats: AMR-NB
  • Video playback file formats: MP4, 3GP; codecs H.263, H.264
  • DRM support: OMA DRM 2 video, Windows DRM-10, WMV
Nokia 7230 Cell... • Answered on Apr 22, 2020
You need active internet connection for streaming or browsing sites.Connecting to Internet requires an active connection. That is depending on the active connection that you will be using for your mobile phone.There are two options for getting active connection:*GRPS*Wi-fi connectionGPRS needs configuration setting from your telephone service provider.It can be provided to you and you will enter it on your phone settings manually. It can also be just sent to you via SMS and you just need to save it. If you are going to ask for these settings from your telephone service provider, tell them to send it to you via OTA (over the air) so you will just save the settings after receiving it.Once you have the settings for you GPRS, you will be able to use the internet but possible data rates will apply.To connect to internet via GPRS:1. Select the web icon from you mobile phones icon.2. You will be asked about what active connection you want to use, select GPRS.3. Once connected, go to the address bar and enter the url/web address that you want to browse. then you're good to go but your mobile account credits will be the one deducted, there will be charges for browsing. This is depending on the terms and agreement that you have with your Telephone service provider.For wifi connection:1. Make sure that you have a working modem router in your premise.2. Turn the modem/router on.3. Select settings icon from your mobile phone.4. Select Wireless Connection or WI-FI connection.5. Select options, then select connect.6. You will be asked for the WEP or WPA key. This is depending on what is the security option that you selected in the modem settings. (for modem settings you can contact your internet service provider or OEM for the modem)7. If you are aware of your pre shared key, just type it in the password option from the mobile screen.8. Once connected, you can use the wifi as your active connection access.9. Open youtube.com then it should be working fine.thanks for choosing www.fixya.com
Nokia 7230 Cell... • Answered on Dec 25, 2018
Hello Dear Friend:::::defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Nokia 7230 Cell... • Answered on May 22, 2018
PASSWORD PROBLEM, IME: 358258038035749 PLS HELP
Nokia 7230 Cell... • Answered on Apr 15, 2018
go to menu then click settings, security, change security code, type 12345 (default security code). after this step the phone will ask you to enter a new code after this, you will be asked to verify the code (need to retype your new security code then) then, your code is changed.
to activate the security code for your phone to use:
1. go to settings
2. choose security
3. choose security level
4. choose phone
5. restart your phone
after the restart, you will be asked to type first your new personalized security code before you can use your phone.
Nokia 7230 Cell... • Answered on Dec 30, 2016
the question is not clear whether u want to block an out going number or incoming number.
i take that as blocking an incoming number:
u have to call ur network operator and ask them to block certain number. this is the only possible way.
Nokia 7230 Cell... • Answered on Nov 04, 2016
Hi, when ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
You will need to service the phone for the phone to be free from water,cause if the water dries inside the phone it will damage an IC or a chip inside the phone and it might cause more damage to the phone.
After, disassembling the phone is the next step.
Get a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the processyou are charging the battery of the phone.
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
You can visit the below link to learn more about flashing of phones.
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Nokia 7230 Cell... • Answered on May 23, 2016
Write your answer... my nokia 7230 manu+up+bown kay not warking
Nokia 7230 Cell... • Answered on Apr 20, 2016
pin blocked enter puk code nokia 7230
Nokia 7230 Cell... • Answered on Feb 11, 2016
Hi there, Please use the following link and follow the instructions to get the master code for your nokia device http://www.nokiamastercode.com/
Nokia 7230 Cell... • Answered on Sep 08, 2015
You need to contact your service provider for PUK code
they can give PUK code after your identity verification
contact your customer care and ask PUK code
Nokia 7230 Cell... • Answered on Jul 28, 2014
hard reset like diz 3573677e-fa6c-4fbe-8427-733acd8e8d51.jpg note: all data will deleted
Nokia 7230 Cell... • Answered on Jul 06, 2014
Do you mean the screen is white? Because that means your device is "hard bricked"(a stage that means corrupted inside, or faulty hardware, this means it could be your phones hardware, or a important part of your phone is corrupted), or maybe the display flex or cable in your phone is broken or misattached.
Nokia 7230 Cell... • Answered on Jun 22, 2014
Nokia 7230 Cell Phone Logo
546 questions posted
Popular Products
Top Nokia Cell Phones Experts
Resolution IT Dubai
Resolution IT Dubai
matt
matt
aliasger yq
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
block no
  • Cell Phones
