Question about Stanley Tools & Hardware - Others
I have a very old Bostitch staple gun Model T5. It has run out of staples, but I cannot figure out how to put new staples in it.
Posted by parkerwr on
  • 1 more comment
  • Help if I Can
    Help if I Can Mar 07, 2015
    Here is some help
  • Help if I Can
    And the rest
  • Janet dunkley Nov 20, 2019
    Can you send me this manual again it's very blurry to [email protected] please I'm having trouble with my stapler yes it's old but my staples are getting jammed every time don't know what else to do thank you
Dave
  • 34 Answers
You should not need any tools to lift the guard/nose piece. The T5 nose piece cleary has engraved on it "Pull Up To Insert Staples". To remove old staples, use a pencil or similar rod to depress the hammer/striker above the staples while the nose is open.
Posted on Aug 07, 2010
  • Dave Dec 21, 2010
    You can buy them on the internet. Do a google search for T5 staples and should get some sources. I bought a case a couple years ago so I wouldn't run out. They come in various lengths.
    Blackwoods sell them
Melissa Yingst
I have one of the old Bostitch T5 staplers. This thing is ancient. It belonged to my dad and hadn't been used in a while. It still works and still has staples in it. I couldn't figure out how to reload it. A search turned up this link, which is exactly what I needed. I might add that you have to pull back on that nose piece a bit before it will come up. I used a flat screwdriver to help me out a bit, as it was resistant, having not been used in so long. Hope this helps som eone else.
http://www.manualnguide.com/shared/bostitch-t5-6-t5-8-and-t5-12-tacker-series-3/127/
Posted on Nov 29, 2012
  • 2 more comments
  • Help if I Can
    Here is some help for others
  • Help if I Can
    More Help with Operating Instructions
    This is blurry
  • Box Morton Nov 24, 2020
    Melissa, you're a fox... "I might add that you have to pull back on that nose piece a bit before it will come up."
    That is the pivotal instruction that only you seemed to understand. Some things just take a woman to explain.
Margo Smith
    New Friend:
What size staples fits this stapler?
Posted on Jun 07, 2013
Anonymous
    New Friend:
I just picked one up at a garage sale. Looking at the gun with handle to the left. Pull out the thing that looks like a cross slightly and swing it around. Be careful, the staples shot out quick.
BTW. There is no where on the stapler that states 'load staples here'.
Posted on Jul 04, 2010
  • mlsaks Dec 21, 2010
    I have the same stapler. Thirty years ago I went to different hardware stores to try to find someone who could figure it out. Finally a very old man showed me how simple it was and I was amazed.(There is no "pull up to insert staples" engraving.) Just the other day my 28 year old son who had borrowed it and is always very good at figuring out things, related to me that he couldn't figure out how to open it when he had run out of staples. I happily showed him how. Now our problem is we don't have any more staples and I can't figure out what size to buy. Does anyone know?
  • ultragreen Dec 14, 2012
    my model t5 does say it right on the top of where the staple shoot out. thanks for the tip mine was jammed and i couldnt figure it out
sue3003334
    New Friend:
  • 6 Answers
I had the same problem - when I put my glasses on I looked at the end of the gun and read this inscription: "lift to insert staples". Guess what - it works! I did need a screww driver to encourage it to flip up though.
Posted on Feb 01, 2010
  • Meryl Fox Sep 30, 2010
    Thank you Sue, now I just need to get the damn thing to work.
Anonymous
    New Friend:
Just solved this with my own T5. When you squeeze the handle and hold it down, you'll see a nut/bolt at the end opposite of the staple opening. Unscrew it and pull the cover off. It may take some effort, but it comes off. Now you can lift the depressor plate out without having to pry it up. In one motion, push the front piece back to get it off the tabs and then up to open. insert staples and reverse the process to reassemble.
Posted on Mar 27, 2011
  • Anonymous Mar 27, 2011
    Ignore this solution. Completely wrong. Sorry.
ultragreen
    New Friend:
  • 4 Answers
Awesome stapler fixed my old couch with it. thanks for the tips on reloading/unjamming
Posted on Dec 14, 2012
Rodger Winch
    New Friend:
  • 3 Answers
If it is stuck/stiking try lubrcating it. WD40 (or similer) will do it wonders.
Posted on Jan 26, 2013
Tyler G
    New Friend:
Don't use wd40 it attracts dust, I like using teflon spray (white)
Posted on Oct 22, 2015
What staples can be used in my Bostitch hand stapler model T5
normally the staples are the same as the stapler designation
look for t5 staples
take on into the local hardware shop and ask for the staples
May 02, 2015 | Staples Tools & Hardware - Others
I have jammed a bostitch t5 staple gun and would like to know how to unjam it
if you take the pins out that hold the front off it will allow you to get at the jammed staple but be careful how every thing comes apart it will not work if shims and washers are not replaced right
Mar 14, 2011 | Aerobie Arrow Staplebrad Gun T50pbn
How to remove staples from bostitch T5 model only to change type of staples
Lift the hinged guard on the front of the stapler and while open use a pencil or similar object to depress the striker (above the staples). This will release the spring catch and the staples will move forward. Use caution and catch the staples as they come out under spring pressure.
Jul 28, 2010 | Stanley Bostitch HP118K 23 Gauge Headless...
I have a Bostitch stapler "gun" that was my Dad's - a T5. Can I get stapes for this?
Yes you can. Google T5 staples and you'll get a lot of responses. I still use my Dad's every day on the job. Nice stapler
Jul 11, 2010 | Tools & Hardware - Others
Directions for Arrow JT-21 staple gun
The jt 21 is that little red one, I have one in my shooting box, only takes the jt staples, and operates just like any staple gun. Feed it from the back.
Feb 20, 2010 | Hand Tools
Where can I download a manual for Bostitch T5 Staple Gun
If you want to know how to load the staples, lift the wee flap at the end with the inscription " lift to insert staples".....
Jan 23, 2010 | Stanley Hand Tools
Tools & Hardware - Others Logo
21,524 people viewed this question
Top Stanley Tools & Hardware - Others Experts
JOHN LAPIER
Paul Carew
Joe Garcia
Joe Garcia
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
