Restart instructions descaling procedure - Step 18-25
1) Empty the large container and the drip tray and place them back
2) Rinse the water tank and fill it up to the MAX level with fresh water. Put it back in the machine
3) When the green 2 CUPS light turns on, turn the control dial to the HOT WATER position
4) The machine dispenses through the hot water/ steam wand until the water tank is empty
5) After this, the machine turns off. The red EXCLAMTION light switches off. Turn the control dial to the BEAN position
6) Rinse the drip tray and put it back. Reinstall the pannarello/ cappuccinatore and INTENZA+ water filter (if applicable)
7) Rinse the water tank and fill it up to the MAX level with fresh water. Put it back in the machine
8) To make coffee, turn on the machine
SOURCE: Saeco Primea Ring stuck on warming up
Hi
I had the same problem and could solve it but i had take the machine apart.
Under boiler you have 2 thermo fuses that can be resetted. After reset i have checked if boiler get 220volt, It did for a short while but the fuses goes off again.
That means boiler is ok, it gets hot but fuses goes of due to temperature reach over 170 degrees celcius. That means that the power is olways on to the heater and doesnt stop to heat.
In diagnostic i could see that the temperature sensor does show the high temperature. That means that temp. sensor is ok which leads to the controller of the power to boiler. On the board i found big heatsink and a triac atached to it. I soldered it out and measure that it was spoiled.
Ordered new one for 3 euro. Soldered new one on the board and the problem was solved.
Original was BTA16-700CW but they didnt have it so i replaced it with BTA16-600CW, difference is that original one can handle 700volt the new one 600, but there is only 220volt it will controll anyway so that was ok.
I atach a picture.
Regards, Pawel
SOURCE: My saeco xsmall has red light continuously on after rinsing
You have to turn the button to the side where is the icon of the cup.
Then you have to wait until the machine stops running water by itself.
