20 Most Recent Saeco Nina Plus Bar Espresso Machine Questions & Answers
Saeco Gran Baristo has E05 error. Restarting doesn't resolve the error.
hi you have problem in water circuit ,either block steam boiler or one of tubes in or out , also can be electric valve if there is . Any case you have to open the machine and find out regards Guy
7/31/2021 2:23:34 PM • Saeco Coffee... • Answered Yesterday
How to speed up Saeco Royal Professional Warming Up process?
ask a Saeco dealer
5/12/2021 3:05:21 PM • Saeco Coffee... • Answered on May 12, 2021
Odea. What is the correct connection for the 4 power switch wires?
when you work on things don't you write down what went where
4/24/2021 2:56:27 PM • Saeco Coffee... • Answered on Apr 24, 2021
Is there a way to factory reset my Saeco Xsmall settings?
Restart instructions descaling procedure - Step 18-25 1) Empty the large container and the drip tray and place them back 2) Rinse the water tank and fill it up to the MAX level with fresh water. Put it back in the machine 3) When the green 2 CUPS light turns on, turn the control dial to the HOT WATER position 4) The machine dispenses through the hot water/ steam wand until the water tank is empty 5) After this, the machine turns off. The red EXCLAMTION light switches off. Turn the control dial to the BEAN position 6) Rinse the drip tray and put it back. Reinstall the pannarello/ cappuccinatore and INTENZA+ water filter (if applicable) 7) Rinse the water tank and fill it up to the MAX level with fresh water. Put it back in the machine 8) To make coffee, turn on the machine
4/5/2021 10:29:18 AM • Saeco Coffee... • Answered on Apr 05, 2021
Vienna De Luxe. Why isn't it brewing coffee?
if no hot water comes thru it then suspect boiler
3/27/2021 1:20:31 AM • Saeco Coffee... • Answered on Mar 27, 2021
I have a Philips Saeco Minuto coffee machine and would like to enter in the service menu to reset the de-scale process. I did that in the past but forgot what keys I need to press for it.
https://www.weeklytools.com/category/coffee-grinder/ This post is for you if you don't feel comfortable making out the usually powdered coffee packets every day. we will discuss about coffee maker with grinder. Assuming you prefer to get the real taste by crushing it with your own hands with direct coffee beans. It is better to drink regular coffee made with
3/11/2021 9:46:53 PM • Saeco Coffee... • Answered on Mar 11, 2021
Saeco Odea Giro Plus fast blinking exlamation mark error
Are multiple problems: 1) the moving mechanism needs to be cleaned, can be blocked. 2) The heating system can have problems. My recommendation is to service it.
2/1/2021 10:10:44 AM • Saeco Coffee... • Answered on Feb 01, 2021
I have Saeco Magic Cappuccino Combi and I changed my pump. The online fuse that is on the water pump was burned/fused and I could not see the specs for it. Do you know the specs for this fuse?
The Parts Schematic does't show one, just a thermal fuse on the frother / steam injector. Saeco are not a nice company to deal with based on a query I dealt with last week. A 3 grand machine and they wanted a guy to pay for them to tell him how to reset it himself! https://coffeemachineparts.com.au/index.php/coffee-machine-parts/saeco-spare-parts/saeco-magic-cappuccino-spare-parts ..
12/1/2020 5:57:39 PM • Saeco Coffee... • Answered on Dec 01, 2020
Why is royal saeco cosuddenly blowing fuses in outlets?
MUST HAVE A SHORT INTERNALLY
11/25/2020 9:25:32 PM • Saeco Coffee... • Answered on Nov 25, 2020
Saeco primea touch stuck on energy saving screen and block
I think there should be a "Go Back " button where the "Energy Saving" button was. file:///C:/Users/Desktop/AppData/Local/Temp/saeco-primea-touch-plus-user-manual.pdf
10/21/2020 5:28:48 PM • Saeco Coffee... • Answered on Oct 21, 2020
Saeco Incanto Deluxe won't cycle out of ventilate mode. Tried all the typical solutions to no avail.
https://www.youtube.com/watch?v=CQUgISjMa3w
4/15/2020 9:45:12 AM • Saeco Coffee... • Answered on Apr 15, 2020
Saeco hd8645 wont heat
https://www.youtube.com/watch?v=mdtPvpPp86c https://www.youtube.com/watch?v=XvIHrQiWoKY
3/26/2020 4:45:08 PM • Saeco Coffee... • Answered on Mar 26, 2020
tip
Fix Drip in Steam Wand for Starbucks Saeco Barista
To fix a dripping steam wand: First empty the water tray and unplug the unit. Then remove the six metal tapping screws from back of unit. The back lifts off as there is a flange at the top to hold on the metal cover. For some reason, the bottom two screws have lock washers. On the steam wand there is a recessed set screw that may be removed with an Allen wrench to open the steam wand. The steam wand stem twists out. Inside and stuck in the unit rather than the stem is a pin with a white plastic washer on it. I removed that, cleaned out the unit and the plastic washer. I found that q-tips worked best. I then reassembled after cleaning various parts. Watch the flange when putting the metal cover onto the back of the unit. Voila! No drip.
0answers
Saeco Nina Plus Bar Espresso Machine Logo
Popular Tags
0 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
eyecam
Ekse
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Saeco Coffee Makers & Espresso...
  • Saeco Coffee Makers & Espresso...
Most Popular Question
saeco magic cappuccino combi changed
  • Coffee Makers & Espresso Machines
