Connectivity error is the most common issues when you are using a wireless network. A simple mistake can show network undetected error. But do not de-stress yet. We have listed down suitable solutions to take care of this error.
Solution1: Make Sure the Wireless Router is Turned On
First of all, you need to check that the wireless router that you are using is power on or not. It is the first and prime step. Make sure, all other connected devices are properly on and attached.
Check the WLAN LED indicator on your wireless router. Make sure it is on and also flashing. Also check the Wi-Fi on and off button. Do not forget to enable the Wi-Fi.
Solution2: Keep your Modem nearby your system
Make sure the printer and the router and the system that you are using are in the same room. All the products need to be within the Wi-Fi range to build up proper connection.
Solution3: Turn on the Router and Wait
The wireless hardware takes some time to update. It requires a couple of minutes to be turned on properly. Turn of your computer and leave it for few minutes. And thus check whether the network name is showing on the list or not.
Solution4: Check whether the network is hidden or not
Also check the network that you are using to connect your printer with your computer is hidden or not. If it is hidden, you have to follow alternative approach. You will need a different method to connect you printer with laptop or computer.
Testimonial: "I think my report of '32 2-sided error' is more specific, primarily relating to Canon i-sensys LBP6650dn. Unfortunately the shop where I bought it has closed down."
SOURCE: canon ip1880 printer service error 5202
Error 5202 means: UNRECOVERABLE ERROR. You need to return your printer to where you bought it and replace a new one if it is still under warranty.
SOURCE: canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
SOURCE: MP560 Canon Printer Error 6C10
The above suggestion worked short term, but in about a couple of hours, I'd get the same old error code again. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
Don't know if you've found an answer to this problem yet, but I had the same issue for about three months. Finally, I found a solution that worked for my MX860 on fixya.com written by "pineworks". The link is as follows: http://www.fixya.com/support/t4097826-aborber_full_error_message
For months, I've had to power off, disconnect from computer, and power on again to kick-start the printing. It was driving me crazy. So far, "pineworks" solution has been a permanent one. Been about a week and have had no problems yet.
SOURCE: Canon MX328
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
error 5100 :
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
