NSIC (National Small Industries Corporation) is a government enterprise under the supervision of Ministry of micro, small and medium enterprises (MSME). It has been constituted to promote and help the MSME industry by proposing many schemes such as single point registration of government purchase, marketing support and more. It helps MSME business players to grow their business and market effectively.
https://www.gsbtaxation.com/in/nsic-registration-consultants-in-mumbai
Https://printcopy.info/?l=en&mod=erc&brand=Canon&model=iR105&page=4
Departure from home position is not detected within 5 sec during a horizontal registration home position search.
Home position is not detected within 5 sec during a horizontal registration home position search.
The horizontal registration detection movement for the preceding sheet does not end within 5 sec at the start of a horizontal registration search during printing.
Canon iR105 Error Codes List page 4 from 14
SOURCE: Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
SOURCE: i have a problem in my canon IR105 it started with
The knurled belt motor is faulty. The knurled belt home position
sensor is faulty.
Condition
0001 The knurled belt motor does not return to home position when the
knurled belt motor is driven for 1 sec or more.
0002 The knurled belt does not leave home position when the knurled
Check motor and sendor in the finisher, if not solved - there are an technician required to set sensor, deatach the finisher from the copier & unplug their socket from copier and operate copier without finisher when technician not come.
SOURCE: i found error in canon ir7105, and i checked
According to the code, the problem is in the laser unit. It sounds like I'm talking to a technician, so I'll approach the problem that way. I personally would first reseat all the electrical connectors on the main PCB as well as the laser unit. Loose connections do sometimes cause codes like this one. The other thing I'd do before tossing the laser unit is to reset the error code because again, codes like this one do come up when the AC power fluctuates from time to time. This is accomplished by entering service mode and then resetting the error . . . your service manual for the ir105 will give you the same method for service model access and the general sequence is the same for resetting the error. Good luck.
SOURCE: hi every one.i have canon copier ir105 gives me
maybe the dc controller is also need to replace or try to reset the error first to reset the error code press * 2&8 simultaniously,* then select copier, then select function, then select clear, then select error, then press ok & turn off & on the power switch
